HP EliteDesk 705 G1 SFF AMD A10 PRO-7800 4GB 500GB Windows 7 Professional 64-bit
Quicklinx: BC30WS00 Mfr#: J4V14EA#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
Designed to perform, impress, and protect-this sleek HP EliteDesk helps you power through to business success while allowing customized deployment with HP's broadest range of form factors.
  • The solution for diverse business demands
    The new way to do business. Impress and perform like never before-and meet a variety of business demands-with highly customizable tools and a stylish new design.
  • Pure performance
    Unlock the full potential of your PC. The latest AMD PRO A-Series APUs with HSA architecture that maximizes efficiency by intelligently prioritizing system tasks between the CPU and GPU.
  • Heavy security, exceptionally managed
    Keep it secure, keep it simple. IT efficiency reigns supreme when it's backed by a full portfolio of security solutions, including HP BIOSphere and HP Client Security.
  • Expand with ease
    Extend the life of your purchase. Using the tool-less chassis this easily upgradable platform features up to 4 expansion slots, 10 ports and multiple connectors to help you meet growing demands.
  • Simplify device management
    Reduce the complexity of administration. HP Client Management and DASH compliant devices help you easily and affordably manage assets.
  • Features
    Enjoy the stunning graphics provided by affordable AMD Radeon Graphics.Get fast access to the data and applications your business demands with solid-state hybrid drive options.HP BIOSphere keeps mission-critical data and systems protected with customizable security.Guard your data, device and identity with HP Client Security.With TPM 1.2 your critical data has protection with hardware-based encryption keys.
HP EliteDesk 705 G1 - SFF - A10 6800B 4.1 GHz - 4 GB - HDD 500 GB - TAA Compliant
Personal computer - small form factor - power-on password, serial port I/O control, USB port control, DriveLock, Setup Password
AMD A10 6800B / 4.1 GHz (, up to 4.4 GHz, (Quad-Core)
Processor Socket
Socket FM2
Cache Memory
4 MB L2 Cache
Cache Per Processor
4 MB
RAM
4 GB (installed) / 32 GB (max) - DDR3 SDRAM - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
15 in 1
Graphics Controller
AMD Radeon HD 8670D
Audio Output
Stereo - integrated
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Software Included
Skype, Windows 7 Professional 64-bit recovery DVD, Microsoft Security Essentials, HP ePrint, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, HP Client Security, HP PageLift, Windows 8.1 Pro 64-bit recovery DVD, Box.net 50GB storage, Drive Encryption
33.8 cm x 38 cm x 10 cm
7.6 kg
TAA Compliant
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Recommended Use
Small business, corporate business
Product Form Factor
Small form factor
Built-in Devices
Solenoid hood lock
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
AMD A10 6800B
Clock Speed
4.1 GHz
Max Turbo Speed
4.4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
Socket FM2
Chipset Type
AMD D4
Cache Memory
Installed Size
L2 Cache - 4 MB
Cache Per Processor
4 MB
RAM
Installed Size
4 GB / 32 GB (max)
DDR3 SDRAM
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
4 (Total) / 3 (empty)
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
15 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
AMD Radeon HD 8670D
Video Interfaces
VGA, DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS Studio Sound
Integrated
Ethernet Controller
Broadcom BCM5762
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external 3.5" , 1 (total) / 0 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5"
Slots
4 (total) / 3 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 2.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile
6 x USB 2.0 (2 front, 4 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 2 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
Power-on password, serial port I/O control, USB port control, DriveLock, Setup Password
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
ACPI
TAA Compliant
Power supply
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Software
Sustainability Information
ENERGY STAR Certified
33.8 cm
38 cm
10 cm
7.6 kg
10 °C
35 °C
10 - 90% (non-condensing)
