The desktop has evolved. The space saving and functionality-packed HP EliteDesk 705 G1 Desktop Mini includes new AMD PRO A-Series APUs with revolutionary HSA technology that provides a perfect balance of power and performance. That's a smart investment.
Big power
Experience true desktop power with the HP EliteDesk 705 G1 Desktop Mini that can fit almost anywhere vertically or horizontally. The clean, easily serviceable design with integrated wireless antenna allows flexible deployment options to help optimize the workspace. -
Pure performance
Unlock the full potential of your PC. The latest AMD PRO A-Series APUs with HSA technology that helps maximize performance by intelligently prioritizing system tasks between the CPU and GPU. -
Security made simple
Keep it secure, keep it simple. IT efficiency reigns supreme when it's backed by a full portfolio of security solutions, including HP BIOSphere and HP Client Security. -
Simplify device management
Reduce the complexity of administration. HP Client Management and DASH compliant devices help you easily and affordably manage assets. -
Keep all your work in plain sight. Be up to 35% more productive by adding up to three independent displays using the integrated VGA and two DisplayPorts.Rest easy with a PC that has endured 115,000 hours of HP's Total Test Process and is designed to undergo MIL-STD 810G tests.Easily service the HP EliteDesk 705 G1 Desktop Mini. A single thumb screw provides fast access to clearly identifiable and serviceable components.AMD APUs with AMD Radeon graphics deliver impressive performance and visually stunning graphics at an affordable price.Take advantage of new drive technology with an optional M.2 PCIe solid state hard drive module, an internal 2.5" SSD, or even dual drive configurations for more local storage.
- HP EliteDesk 705 G1 - mini desktop - A8 PRO-7600B 3.1 GHz - 4 GB - HDD 500 GB - UK - TAA Compliant
- Personal computer - mini desktop - administrator password, power-on password, USB port control, DriveLock, Setup Password, UEFI BIOS
- Localisation
- Processor
- AMD A8 PRO-7600B / 3.1 GHz (, up to 3.8 GHz, (Quad-Core)
- Cache Memory
- 4 MB L2 Cache
- Cache Per Processor
- 4 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon R7
- Audio Output
- Stereo
- Networking
- GigE, 802.11a, 802.11b/g/n
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, HP Recovery Disc Creator, Skype, Windows 7 Professional 64-bit recovery DVD, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP ePrint, Foxit PhantomPDF Express, HP Spare Key, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP File Sanitizer, Box.net 50GB storage, Drive Encryption, HP Manageability, HP Disk Sanitizer External Edition (free download), Absolute Persistence
- 17.5 cm x 17.7 cm x 3.4 cm
- 1.3 kg
- TAA Compliant
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Product Form Factor
- Mini desktop
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD A8 PRO-7600B
- Clock Speed
- 3.1 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- AMD D4
Cache Memory
- Installed Size
- L2 Cache - 4 MB
- 4 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon R7
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio, DTS Studio Sound
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Interface
- USB
- Ethernet Controller
- Broadcom BCM5762
- Wireless LAN Supported
- Wireless NIC
- Intel Wireless-N 7260
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Remote Management Protocol
- ASF 2.0
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.1as, IEEE 802.11n, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x internal 2.5"
- Slots
- 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x M.2 Card
- 6 x USB 3.0 (2 front, 4 rear) , 1 x VGA , 2 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out
- Included Accessories
- Vertical stand
- Administrator password, power-on password, USB port control, DriveLock, Setup Password, UEFI BIOS
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI
- TAA Compliant
- Power adapter
- Voltage Required
- Power Provided
- 90 Watt
- Efficiency
- 89%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
- Software
Sustainability Information
- ENERGY STAR Certified
- 17.5 cm
- 17.7 cm
- 3.4 cm
- 1.3 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
