The number of devices you need to make an impact is one. Create and present your vision of success on the HP EliteBook x360 1030 with four use modes to get work done, share content, and enjoy some downtime.
Designed for where life takes you
Express yourself in almost any light using the ultra-bright display on the precision-crafted HP EliteBook x360 1030 featuring four inspiring use modes and remarkable audio. -
How life gets done
Be ready when your day pulls you in different directions. Complete your priorities from almost anywhere and with anyone using the remarkable audio and world-facing microphone for enhanced noise cancellation. -
Safe
Control what the world sees and help protect your data with integrated security and privacy features.
- HP EliteBook x360 1030 G4 - 13.3" - Core i5 8265U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit - English
- Platform Technology
- Intel vPro Technology
- Processor
- Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD - NVMe
- Optical Drive
- No optical drive
- Display
- 13.3" WLED touchscreen HP SureView 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- NFC, Bluetooth 5.0, 802.11a/b/g/n/ac/ax wireless cellular modem
- Wireless Broadband (WWAN)
- 4G LTE
- Service Provider
- Not specified
- Battery
- 4-cell - up to 18 hours
- Accelerometer, ambient light sensor, magnetometer, gyro sensor, hall sensor
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- 30.58 cm x 20.5 cm x 1.58 cm
- 1.27 kg
- Localisation
- Environmental Standards
- TCO Certified Notebooks 8, ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- Cache
- L3 - 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology
- RAM
- 8 GB (provided memory is soldered)
- Max RAM Supported
- 16 GB
- Technology
- LPDDR3 SDRAM
- Speed
- 2133 MHz
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 144-pin
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe - NVM Express (NVMe)
Display
- 13.3" - IPS
- LCD Backlight Technology
- WLED backlight
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 1000 cd/m²
- Privacy Technology
- HP SureView
- Bezel Type
- Flat front
- 72% NTSC colour gamut, privacy filter, Panel Self Refresh (PSR), Full HD eDP anti-glare, Corning Gorilla glass 5
- Keyboard Name
- HP Premium Collaboration Keyboard
Audio & Video
- Graphics Processor
- Camera
- Yes - Full HD
- Video Resolutions
- 1080p
- Camera Features
- IR camera
- Sound
- Four speakers, 3 multi-array microphone
- Audio Features
- Bang & Olufsen Audio, 4 discrete amplifiers
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6 AX 200
- Miracast, dual stream (2x2)
- Wi-Fi CERTIFIED
- Generation
- 4G
- Technology
- LTE
- Service Provider
- Not specified
- Technology
- 4-cell lithium polymer
- Capacity
- 56.2 Wh
- Run Time
- Up to 18 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- 2 x USB-C/Thunderbolt , USB 3.1 Gen 1 (charging) , Headphone/microphone combo jack , HDMI
- Integrated Options
- Security
- Automatic DriveLock, HP DriveLock, HP Fast Charge, MU-MIMO technology, HP Fingerprint Sensor, HP Sure Click, HP BIOSphere Gen 5, HP Client Security Gen 5, HP Sure Start Gen 5, HP Sure Run Gen 2, HP Sure Recover Gen 2, HP Secure Erase
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- USB-C power adapter
- Common Criteria EAL4+, low halogen
- Localization
- 1.27 kg
- TCO Certified
- ENERGY STAR Certified
