HP EliteBook x360 1020 G2 Intel Core i7-7500U 8GB 256GB 12.5" Windows 10 Pro 64-bit
Quicklinx: D6HBWS00 Mfr#: 1EQ26EA#ABU
  • Core i7
  • IEEE 802.11n
With 360° of versatility across five modes, unmatched security, and long hours of battery life, the thin and light HP EliteBook x360 1030 is the perfect PC for highly mobile professionals. Wherever business or pleasure takes you, set another benchmark for work and fun.
  • Made to keep moving
    Ultrathin and ultra-bright, the HP EliteBook x360 1020 was inspired by your life on-the-go. With long battery life, HP Fast Charge, and industry-leading ultra-bright 700-nit display, it keeps you moving forward from anywhere.
  • Our most secure and manageable PCs
    Protection is simple and manageable thanks to a cutting-edge suite of security features that lets you browse confidently, keeps visual hackers in the dark, and monitors and restores in memory BIOS automatically.
  • Rule your conference from the road
    When you can be anywhere, hands-on teamwork is vital for staying ahead. Get crisp, clear communication with five speakers tuned with Audio by Bang & Olufsen and manage calls quickly with the HP Premium Collaboration Keyboard.
HP EliteBook x360 1020 G2 - 12.5" - Core i7 7500U - 8 GB RAM - 256 GB SSD - UK
Notebook - flip design
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (7th Gen) 7500U / 2.7 GHz (3.5 GHz) / 4 MB Cache /
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD NVMe, TLC
Optical Drive
No optical drive
Display
12.5" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Input Device
ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
4-cell
Hood sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
29 cm x 20.38 cm x 1.39 cm
1.13 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years , Limited warranty - battery - 3 years
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe - NVM Express (NVMe), triple-level cell (TLC)
Display
12.5" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Ultra Slim Design, Direct Bonding technology, Corning Gorilla glass 4, Full HD ultra wide-viewing angle (UWVA) eDP +PSR
Audio & Video
Graphics Processor
Camera
Yes - 720p
Camera Features
IR camera, Windows Hello
Sound
Stereo speakers, dual array microphone
Audio Features
Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Volume control, multi-touch touchpad, glass with chemical etched surface
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
Miracast, dual stream (2x2)
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
4-cell Lithium Ion
49.28 Wh
AC Adapter
Output
65 Watt, 5 / 9 / 10 / 12 / 15 / 20 V
Connections & Expansion
2 x USB-C 3.1/Thunderbolt 3 , HDMI , Headphone/microphone combo jack
Case Material
Aluminum
Integrated Options
Hood sensor
Security
Power-on password, HP DuraKeys, Setup Password, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, adjustable angle (5 positions), HP Fast Charge, MIL-STD-810G tested, HP Sure Start Gen 3
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
USB-C power adapter
Localization
1.13 kg
ENERGY STAR Certified
