Suddenly, everywhere becomes your office with our thinnest and lightest business convertible. From the office to abroad, go wherever work takes you with high-performance specs, industry-leading security, and immersive collaboration.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful, sleek, thin, and light HP EliteBook x360. -
See it clearly
Pick the right display for the way you work with FHD or UHD touch display. -
Creativity and collaboration go hand-in-hand
Enjoy a natural inking experience with the full-size HP Active Pen with App Launch. Share with the touch of a button on the HP Premium Collaboration Keyboard and discuss your work clearly with HP Noise Cancellation. -
Browse confidently
Help protect your PC from infected websites, malware, ransomware, and viruses with HP Sure Click-hardware-enforced security for web browsers. -
Keep visual hackers in the dark
Instantly protect against visual hacking with the optional HP Sure View integrated privacy screen. At the touch of a button your screen appears unreadable to those around you while you see your content clearly. -
Self-healing safeguard
Start with a genuine HP BIOS every time. HP Sure Start Gen3 monitors in-memory BIOS, recovers the platform without user or admin intervention, restores the BIOS to a custom state, and is enterprise ready for centralized management.
- HP EliteBook x360 1020 G2 Notebook - 12.5" - Intel Core i5 - 7300U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i5 (7th Gen) - 7300U / 2.6 GHz, up to 3.5 GHz / 3 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD - NVMe, TLC
- Display
- 12.5" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 620
- Input Device
- ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 4-cell - up to 15.5 hours
- Hood sensor
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- 29 cm x 20.38 cm x 1.39 cm
- 1.13 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years , Limited warranty - battery - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i5 (7th Gen) 7300U / 2.6 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
- Rated Speed
- 1866 MHz
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), triple-level cell (TLC)
Display
- 12.5" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 400 cd/m²
- Colour Gamut
- 100% sRGB
- BrightView, Ultra Slim Design, Direct Bonding technology, Corning Gorilla glass 4, Full HD ultra wide-viewing angle (UWVA) eDP +PSR
- Keyboard Name
- HP Premium Collaboration Keyboard
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Camera Features
- IR camera, Windows Hello
- Sound
- Stereo speakers, dual array microphone
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Multi-touch touchpad, ClickPad with gesture support, glass with chemical etched surface
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
- Miracast, dual stream (2x2)
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Capacity
- 49.28 Wh
- Run Time
- Up to 15.5 hours
AC Adapter
- Output
- 65 Watt, 5 / 9 / 10 / 12 / 15 / 20 V
Connections & Expansion
- Interfaces Details
- 2 x USB-C 3.1 (supports Thunderbolt 3) , HDMI , Headphone/microphone combo jack
Software
- Software Included
- HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Password Manager, Windows Defender, HP Velocity, HP Drive Packs (free download), HP Client Catalog, HP Credential Manager, HP BIOS Config Utility, HP 3D DriveGuard, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP System Software Manager, HP Client Security Suite Gen3, HP BIOSphere Gen3, HP JetAdvantage, HP Wireless Wakeup, HP Workwise (free download), HP Management Integration Kit for Microsoft System Center Configuration Manager (free download), HP Sure Click
- Case Material
- Aluminum
- Integrated Options
- Hood sensor
- Security
- Power-on password, HP DuraKeys, Setup Password, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, adjustable angle (5 positions), HP Fast Charge, MIL-STD-810G tested, HP Sure Start Gen 3
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- USB-C power adapter
- Localization
- 1.13 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
