HP EliteBook x360 1020 G2 Core i5-7200U 8GB 256GB SSD 12.5" Windows 10 Pro
Quicklinx: DVCDWS00 Mfr#: 1EP68EA#ABU
Display Size: 12.5in
Processor Model: I5-7200U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
£1,428.68 ex VAT
£1,714.41 inc VAT
Suddenly, everywhere becomes your office with our thinnest and lightest business convertible. From the office to abroad, go wherever work takes you with high-performance specs, industry-leading security, and immersive collaboration.
  • Made to keep moving
    Ultrathin and ultra-bright, the HP EliteBook x360 1020 was inspired by your life on-the-go. With long battery life, HP Fast Charge, and industry-leading ultra-bright 700-nit display, it keeps you moving forward from anywhere.
  • Our most secure and manageable PCs
    Protection is simple and manageable thanks to a cutting-edge suite of security features that lets you browse confidently, keeps visual hackers in the dark, and monitors and restores in memory BIOS automatically.
  • Rule your conference from the road
    When you can be anywhere, hands-on teamwork is vital for staying ahead. Get crisp, clear communication with five speakers tuned with Audio by Bang & Olufsen and manage calls quickly with the HP Premium Collaboration Keyboard.
HP EliteBook x360 1020 G2 - 12.5" - Core i5 7200U - 8 GB RAM - 256 GB SSD - UK
Notebook - flip design
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD NVMe, TLC
Optical Drive
No optical drive
Display
12.5" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Input Device
ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
4-cell
Hood sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
29 cm x 20.38 cm x 1.39 cm
1.13 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years , Limited warranty - battery - 3 years
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1866 MHz
Rated Speed
1866 MHz
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe - NVM Express (NVMe), triple-level cell (TLC)
Display
12.5" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
700 cd/m²
Ultra Slim Design, 100% sRGB colour gamut, Direct Bonding technology, privacy filter, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare, Corning Gorilla glass 4, HP Sure View
Audio & Video
Graphics Processor
Camera
Yes - 720p
Camera Features
IR camera, Windows Hello
Sound
Stereo speakers, dual array microphone
Audio Features
Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
ClickPad with gesture support, glass with chemical etched surface
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
Miracast, dual stream (2x2)
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
4-cell Lithium Ion
49.28 Wh
AC Adapter
Output
65 Watt, 5 / 9 / 10 / 12 / 15 / 20 V
Connections & Expansion
2 x USB-C 3.1/Thunderbolt 3 , HDMI , Headphone/microphone combo jack
Software
Software Included
HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Password Manager, Windows Defender, HP Velocity, HP Drive Packs (free download), HP Client Catalog, HP Credential Manager, HP BIOS Config Utility, HP 3D DriveGuard, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP System Software Manager, HP Client Security Suite Gen3, HP BIOSphere Gen3, HP JetAdvantage, HP Wireless Wakeup, HP Workwise (free download), HP Management Integration Kit for Microsoft System Center Configuration Manager (free download), HP Sure Click
Case Material
Aluminum
Integrated Options
Hood sensor
Security
Power-on password, HP DuraKeys, Setup Password, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, adjustable angle (5 positions), HP Fast Charge, MIL-STD-810G tested, HP Sure Start Gen 3
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
USB-C power adapter
Localization
1.13 kg
ENERGY STAR Certified
Software applications
HP EliteBook x360 1020 G2 Core i5-7200U 8GB 256GB SSD 12.5 Bundle deal on HP EliteBook x360 1020 G2 Core i5-7200U 8GB 256GB SSD 12.5" Windows 10 Pro
£1,611.84
saving £8.33
£1,527.85
Optical Storage: None
Graphics: Intel HD Graphics 620
Hard Drive Type: SSD
Touchscreen: Yes
Type: Laptop
Brand: HP
Price Range Ex VAT: 1000 - 1500
