HP EliteBook Revolve 810 G3 Core i7-5600U 8GB 256GB SSD 11.6" Touchscreen Windows 8.1 Pro 64-bit
Quicklinx: BHSTWS00 Mfr#: J8R98EA#ABU
  • Core i7
  • Windows 8.1 Pro 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Work with the enterprise-class EliteBook built to adapt to your needs. The HP EliteBook Revolve 810 transforms to five usage modes all backed by Elite-class durability, performance, security, and manageability for work in the office or on the road.
  • Designed for durability
    HP's ultra-thin full-performance EliteBook Ultrabook that converts to a tablet and is designed to pass MIL-STD 810G tests and features a magnesium chassis and spill resistant keyboard.
  • Bend over backwards flexibility
    Take advantage of built-in flexibility with your choice of input from the optional HP Executive Pen, touchscreen, or keyboard to work with the five usage modes available on the HP EliteBook Revolve 810.
  • No-compromise performance
    Boost your productivity with Windows 8.1, the latest 5th generation Intel Core i3/i5/i7 ULT processor technology, long battery life, enterprise-class docking and high performance storage options.
  • Heavy security, effectively managed
    Get security and manageability tools that ease the burden on IT with optional Intel vPro and a comprehensive suite of tools from HP including HP BIOSphere and HP Sure Start.
HP EliteBook Revolve 810 G3 Tablet - 11.6" - Intel Core i7 - 5600U - 8 GB RAM - 256 GB SSD - 4G LTE - UK
Notebook - convertible
Operating System
Win 8.1 Pro 64-bit - English
Intel Core i7 (5th Gen) - 5600U / 2.6 GHz, up to 3.2 GHz / 4 MB Cache
8 GB DDR3L (1 x 4 GB + 4 GB (soldered))
Storage
256 GB SSD
Display
11.6" LED backlight touchscreen 1366 x 768 / HD
Graphics
Intel HD Graphics 5500
Input Device
Digitizer, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, NFC, Gigabit Ethernet
Wireless Broadband (WWAN)
4G LTE
Service Provider
Service not included
6-cell
Ambient light sensor, proximity sensor
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
28.5 cm x 21.2 cm x 2.22 cm
1.4 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years
Operating System
Windows 8.1 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i7 (5th Gen) 5600U / 2.6 GHz
Max Turbo Speed
3.2 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 4 GB + 4 GB (soldered))
Max RAM Supported
12 GB
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
256 GB SSD M.2 SATA 6Gb/s
Display
11.6"
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1366 x 768 (HD)
Widescreen
Corning Gorilla glass 3, HD ultra wide-viewing angle (UWVA)
Audio & Video
Graphics Processor
Camera
Yes - 720p
Camera Features
720p HD movie recording
Sound
Stereo speakers, two microphones
Codec
Realtek ALC3228
DTS Studio Sound
Input
Keyboard, digitizer, ClickPad
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7265 - PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I218-LM
Miracast
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, Wi-Fi CERTIFIED, IEEE 802.3az
Generation
4G
HSPA+, LTE, Gobi
Controller
HP lt4112 - M.2 Card
Max Transfer Rate
100 Mbps
Service Provider
Navigation
Receiver
A-GPS
6-cell lithium polymer
44 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
Slots
1 x microSD
DisplayPort , Headphone/microphone combo jack , Dock , LAN , 2 x USB 3.0
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
CyberLink Power2Go, Skype, LANDesk Management Suite, HP Support Assistant, Bing Toolbar, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, Absolute Data Protect, Netflix, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Windows Defender, HP Registration, HP Mobile Connect, HP Systems Software Manager (free download), HP PageLift, HP Security Manager, HP Wireless Hotspot, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), Absolute Persistence, HP Roaming Alert, HP Driver Packs, HP CIK for Microsoft SCCM, HP Device Access Manager
Case Material
Magnesium alloy
Integrated Options
Dockable
Security
Security lock slot (cable lock sold separately), digital compass, HP Disk Sanitizer, HP DuraFinish, HP SpareKey, HP File Sanitizer, Accelerometer, HP DuraCase, HP BIOS Protection, gyroscope, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
Power adapter
ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, Common Criteria EAL4+, KC, CIT
Localization
1.4 kg
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
