Work with the enterprise-class EliteBook built to adapt to your needs. The HP EliteBook Revolve 810 transforms to five usage modes all backed by Elite-class durability, performance, security, and manageability for work in the office or on the road.
Designed for durability
HP's ultra-thin full-performance EliteBook Ultrabook that converts to a tablet and is designed to pass MIL-STD 810G tests and features a magnesium chassis and spill resistant keyboard. -
Bend over backwards flexibility
Take advantage of built-in flexibility with your choice of input from the optional HP Executive Pen, touchscreen, or keyboard to work with the five usage modes available on the HP EliteBook Revolve 810. -
No-compromise performance
Boost your productivity with Windows 8.1, the latest 5th generation Intel Core i3/i5/i7 ULT processor technology, long battery life, enterprise-class docking and high performance storage options. -
Heavy security, effectively managed
Get security and manageability tools that ease the burden on IT with optional Intel vPro and a comprehensive suite of tools from HP including HP BIOSphere and HP Sure Start.
- HP EliteBook Revolve 810 G3 Tablet - 11.6" - Intel Core i7 - 5600U - 8 GB RAM - 256 GB SSD - 4G LTE - UK
- Product Type
- Notebook - convertible
- Operating System
- Win 8.1 Pro 64-bit - English
- Processor
- Intel Core i7 (5th Gen) - 5600U / 2.6 GHz, up to 3.2 GHz / 4 MB Cache
- Memory
- 8 GB DDR3L (1 x 4 GB + 4 GB (soldered))
- Storage
- 256 GB SSD
- Display
- 11.6" LED backlight touchscreen 1366 x 768 / HD
- Graphics
- Intel HD Graphics 5500
- Input Device
- Digitizer, ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, NFC, Gigabit Ethernet
- Wireless Broadband (WWAN)
- 4G LTE
- Service Provider
- Service not included
- Battery
- 6-cell
- Ambient light sensor, proximity sensor
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 28.5 cm x 21.2 cm x 2.22 cm
- 1.4 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years
- Product Type
- Operating System
- Windows 8.1 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i7 (5th Gen) 5600U / 2.6 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 4 GB + 4 GB (soldered))
- Max RAM Supported
- 12 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD M.2 SATA 6Gb/s
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Corning Gorilla glass 3, HD ultra wide-viewing angle (UWVA)
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Camera Features
- 720p HD movie recording
- Sound
- Stereo speakers, two microphones
- Codec
- Realtek ALC3228
- DTS Studio Sound
Input
- Keyboard, digitizer, ClickPad
- Keyboard Layout
- UK
- Volume control, spill-resistant
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - PCI Express Half Mini Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- Miracast
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, Wi-Fi CERTIFIED, IEEE 802.3az
- Generation
- 4G
- Technology
- HSPA+, LTE, Gobi
- Controller
- HP lt4112 - M.2 Card
- Max Transfer Rate
- 100 Mbps
- Service Provider
Navigation
- Receiver
- A-GPS
- Technology
- 6-cell lithium polymer
- Capacity
- 44 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Slots
- 1 x microSD
- DisplayPort , Headphone/microphone combo jack , Dock , LAN , 2 x USB 3.0
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- CyberLink Power2Go, Skype, LANDesk Management Suite, HP Support Assistant, Bing Toolbar, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, Absolute Data Protect, Netflix, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Windows Defender, HP Registration, HP Mobile Connect, HP Systems Software Manager (free download), HP PageLift, HP Security Manager, HP Wireless Hotspot, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), Absolute Persistence, HP Roaming Alert, HP Driver Packs, HP CIK for Microsoft SCCM, HP Device Access Manager
- Case Material
- Magnesium alloy
- Integrated Options
- Dockable
- Security
- Security lock slot (cable lock sold separately), digital compass, HP Disk Sanitizer, HP DuraFinish, HP SpareKey, HP File Sanitizer, Accelerometer, HP DuraCase, HP BIOS Protection, gyroscope, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, Common Criteria EAL4+, KC, CIT
- Localization
- 1.4 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
