HP EliteBook Revolve 810 G2 Core i5-4300U 4GB 180GB SSD 11.6" Touchscreen Windows 8.1 Pro 64-bit
Quicklinx: BHGBWS00 Mfr#: F6H58AW#ABU
Display Size: 11.6in
Processor Model: I5-4300U
Operating System: Windows 8.1 Pro 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 180GB
  • Core i5
  • Windows 8.1 Pro 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
£1,489.76 ex VAT
£1,787.71 inc VAT
Work doesn't always adapt to you. So we designed an HP EliteBook that does. It's an ultra-thin notebook that rotates to become a tablet in an instant. The EliteBook Revolve bends over backwards to help you get more done.
  • Designed for durability
    This ultra-thin full-performance EliteBook converts to a tablet. It also is designed to pass MIL-STD 810G tests and features a magnesium chassis and spill resistant keyboard.
  • No compromise performance
    Boost your productivity with Windows 8.1, the latest 4th generation Intel Core i3/i5/i7 ULT processor technology, and a solid-state drive (SSD). Get connected with optional 4G LTE WWAN, HP ePrint, and enterprise-class docking.
  • Heavy security, efficiently managed
    Security and manageability tools for enterprise and SMB that ease the burden on IT, including HP Sure Start self-healing BIOS.
  • Even more
    More tools so you stay productive.
HP EliteBook Revolve 810 G2 Tablet - 11.6" - Core i5 4300U - 4 GB RAM - 180 GB SSD
Notebook - convertible
Operating System
Win 8.1 Pro 64-bit
Platform Technology
Intel vPro Technology
Intel Core i5 (4th Gen) 4300U / 1.9 GHz (2.9 GHz) / 3 MB Cache
4 GB DDR3L (provided memory is soldered)
Storage
180 GB SSD
Optical Drive
No optical drive
Display
11.6" LED backlight touchscreen HD UWVA anti-glare 1366 x 768 / HD
Graphics
Intel HD Graphics 4400
Input Device
ClickPad
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, NFC, Gigabit Ethernet
6-cell
Ambient light sensor
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip
28.5 cm x 21.2 cm x 2.22 cm
1.4 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years , Limited warranty - battery - 1 year
Recommended Use
Small business, corporate business
Operating System
Processor / Chipset
CPU
Max Turbo Speed
2.9 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Chipset
Intel QM87
Platform Technology
Intel Turbo Boost Technology 2.0
RAM
4 GB (provided memory is soldered)
Max RAM Supported
12 GB
DDR3L SDRAM
Speed
1600 MHz / PC3-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
1
Empty Slots
1
Storage
Main Storage
180 GB SSD M.2 SATA 6Gb/s
Display
11.6"
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1366 x 768 (HD)
Widescreen
Intel Display Power Saving Technology (DPST), Corning Gorilla glass 3, HD ultra wide-viewing angle (UWVA) anti-glare
Audio & Video
Graphics Processor
Camera
Video Resolutions
1280 x 720
Sound
Stereo speakers, stereo microphone
Codec
IDT 92HD91
High Definition Audio, DTS Studio Sound
Input
Keyboard, ClickPad
Keyboard Backlight
Volume control, spill-resistant
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-N 7260AN
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel 82579LM
Remote Management Protocol
SNMP 2
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, Wi-Fi CERTIFIED, IEEE 802.3az
6-cell lithium polymer
44 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
DisplayPort , Headphone/microphone combo jack , Dock , LAN , 2 x USB 3.0
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Adobe Flash Player, HP Recovery Disc Creator, Skype, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Setup, HP Hotkey Support, PDF Complete Corporate Edition, Absolute Data Protect, HP Performance Advisor, Netflix, HP Wallpaper, Microsoft Internet Explorer 10, Windows Defender, HP Registration, HP Client Security, Device Access Manager with Just In Time Authentication, HP Quick Start, HP PageLift, Box.net 50GB storage, HP Trust Circles Standard, HP Manageability, HP Firmware & Driver Installer
Case Material
Magnesium alloy
Integrated Options
Dockable
Security
Security lock slot (cable lock sold separately), digital compass, charging via USB, Intel Active Management Technology (iAMT), HP DuraFinish, HP SpareKey, One-Step Logon, Accelerometer, HP DuraCase, HP BIOS Protection, gyroscope, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security
Power adapter
ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, Common Criteria EAL4+, KC, CIT
Localization
1.4 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance
40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance
0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
Optical Storage: None
Graphics: Intel HD Graphics 4400
Hard Drive Type: SSD
Touchscreen: Yes
Type: Ultrabook
Brand: HP
Price Range Ex VAT: 1000 - 1500
