Work doesn't always adapt to you. So we designed an HP EliteBook that does. It's an ultra-thin notebook that rotates to become a tablet in an instant. The EliteBook Revolve bends over backwards to help you get more done.
Designed for durability
This ultra-thin full-performance EliteBook converts to a tablet. It also is designed to pass MIL-STD 810G tests and features a magnesium chassis and spill resistant keyboard. -
No compromise performance
Boost your productivity with Windows 8.1, the latest 4th generation Intel Core i3/i5/i7 ULT processor technology, and a solid-state drive (SSD). Get connected with optional 4G LTE WWAN, HP ePrint, and enterprise-class docking. -
Heavy security, efficiently managed
Security and manageability tools for enterprise and SMB that ease the burden on IT, including HP Sure Start self-healing BIOS. -
Even more
More tools so you stay productive.
- HP EliteBook Revolve 810 G2 Tablet - 11.6" - Intel Core i5 - 4300U - vPro - 4 GB RAM - 128 GB SSD
- Product Type
- Notebook - convertible
- Operating System
- Win 8.1 Pro
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i5 (4th Gen) - 4300U / 1.9 GHz, up to 2.9 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (provided memory is soldered)
- Storage
- 128 GB SSD
- Display
- 11.6" LED backlight touchscreen 1366 x 768 / HD
- Graphics
- Intel HD Graphics 4400
- Input Device
- ClickPad
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.0, NFC, Gigabit Ethernet
- Battery
- 6-cell - up to 10.75 hours
- Ambient light sensor
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 28.5 cm x 21.2 cm x 2.22 cm
- 1.4 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years
- Product Type
- Recommended Use
- Small business, corporate business
- Operating System
- Windows 8.1 Pro
Processor / Chipset
- CPU
- Intel Core i5 (4th Gen) 4300U / 1.9 GHz
- Max Turbo Speed
- 2.9 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Chipset
- Intel QM87
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (provided memory is soldered)
- Max RAM Supported
- 12 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 1
- Empty Slots
- 1
Storage
- Main Storage
- 128 GB SSD M.2 SATA 6Gb/s
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Intel Display Power Saving Technology (DPST), Corning Gorilla glass 3, HD ultra wide-viewing angle (UWVA) anti-glare
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Video Resolutions
- 1280 x 720
- Sound
- Stereo speakers, stereo microphone
- Codec
- IDT 92HD91
- High Definition Audio, DTS Studio Sound
Input
- Keyboard, ClickPad
- Volume control, spill-resistant
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-N 7260AN - PCI Express Half Mini Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel 82579LM
- Remote Management Protocol
- SNMP 2
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 6-cell lithium polymer
- Capacity
- 44 Wh
- Run Time
- Up to 10.75 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- DisplayPort , Headphone/microphone combo jack , Dock , LAN , 2 x USB 3.0
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, Computrace, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Setup, HP Hotkey Support, PDF Complete Corporate Edition, Absolute Data Protect, HP Performance Advisor, Netflix, HP Wallpaper, Amazon Kindle, Microsoft Internet Explorer 10, Privacy Manager, HP Registration, HP Client Security, Device Access Manager with Just In Time Authentication, HP Quick Start, HP PageLift, HP Secure Erase, Box.net 50GB storage, HP Trust Circles Standard, HP Ceement, HP Manageability, HP Wireless Button Driver, HP Validity Fingerprint Driver, HP Firmware & Driver Installer, HP UEFI System Diagnostics
- Case Material
- Magnesium alloy
- Integrated Options
- Dockable
- Security
- Security lock slot (cable lock sold separately), digital compass, charging via USB, HP 3D DriveGuard, Intel Active Management Technology (iAMT), HP DuraFinish, HP SpareKey, One-Step Logon, HP File Sanitizer, Accelerometer, HP DuraCase, HP BIOS Protection, gyroscope, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, Common Criteria EAL4+, KC, CIT
- Localization
- 1.4 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance
- 40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
- Vibration Tolerance
- 0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
