Beauty runs deep on HP's thinnest enterprise-class 35,56 cm (14") diagonal Ultrabook packed with impressive performance, security, and manageability features to help bring out your finest work.
Convenient collaboration
Collaborate with colleagues using a 720p webcam and noise-canceling DTS Studio Sound. -
Easy connections
Essential ports provide convenient connections to peripheral devices. The DisplayPort allows fast connections to monitors and projectors, while USB 3.0 charging ports on either side of the machine allow for hassle free charging of mobile devices. -
Adapt to your work style
Help boost efficiency with optional accessories like the Ultraslim Docking Station, Elite Displays, and small AC Travel adapter to match your personal work style. -
Road ready
Never fear accidental bumps on the durable HP EliteBook 1040. -
Customized protection
HP BIOSphere keeps mission-critical data and systems protected with customizable security. -
Self-healing safeguard
HP Sure Start detects corruption and self-heals the BIOS.
- HP EliteBook Folio 1040 G2 - 14" - Intel Core i7 - 5600U - vPro - 8 GB RAM - 256 GB SSD - 4G LTE - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i7 (5th Gen) - 5600U / 2.6 GHz, up to 3.2 GHz / 4 MB Cache
- Memory
- 8 GB DDR3L (1 x 4 GB + 4 GB (soldered))
- Storage
- 256 GB SSD
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 5500
- Input Device
- ForcePad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, NFC, Gigabit Ethernet
- Wireless Broadband (WWAN)
- 4G LTE
- Battery
- 6-cell
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, smart card reader
- Platinum
- 33.8 cm x 23.35 cm x 1.59 cm
- 1.51 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years , Limited warranty - battery - 3 years
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Processor / Chipset
- CPU
- Intel Core i7 (5th Gen) 5600U / 2.6 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 4 GB + 4 GB (soldered))
- Max RAM Supported
- 8 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD M.2 SATA 6Gb/s
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
- Codec
- IDT 92HD91
- High Definition Audio, DTS Studio Sound, DTS SOUND+
Input
- Keyboard, ForcePad
- Keyboard Layout
- UK
- Volume control, spill-resistant, multi-touch touchpad
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 7265
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- Gobi Technology
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
- Generation
- 4G
- Technology
- GPRS, HSPA+, LTE
Navigation
- Receiver
- GPS
- Technology
- 6-cell lithium polymer
- Capacity
- 42 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- DisplayPort , Headphone/microphone combo jack , Dock , 2 x USB 3.0 , VGA (on supplied cable) , LAN (on supplied cable)
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP ePrint, Device Access Manager, HP Wireless Hotspot (free download), HP Client Security, HP Mobile Connect, HP Secure Erase, Drive Encryption, HP Trust Circles Standard
- Platinum
- Case Material
- Aluminum
- Dockable
- Security
- HP DuraFinish, HP DuraKeys, HP DisplaySafe, HP SureStart, Full Volume Encryption, 1 USB 3.0 charging port
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- Cables Included
- HP Dock to VGA+LAN adapter
- ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC, CIT
- Localization
- 1.51 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
