HP EliteBook Folio 1040 G1 Intel Core i7-7600U 8GB 256GB SSD 14" Windows 7 Professional 64-bit
Quicklinx: BHGKWS00 Mfr#: H5F65EA#ABU
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
This elegantly designed HP EliteBook is our thinnest business Ultrabook yet. The HP Elitebook Folio 1040 is packed with enterprise-class features like docking capability and premier security to help keep you productive and your data safe.
  • Carry less
    At just 15.9mm thin, it's our thinnest EliteBook yet. Choose between a 3mm HD or FHD display with all the mobility you'd expect from an Ultrabook.Engage in videoconferences, web-based trainings or streaming videos with smooth audio quality, thanks to DTS Studio Sound and your notebook speakers.Get more done in low light and worry less over minor accidental spills with the backlit spill- resistant keyboard.
  • Security you can depend on
    HP Sure Start restores productivity and reduces IT help desk calls in the event of a BIOS attack or corruption.Keep productivity high and downtime low with the automated features of HP BIOSphere.Safeguard data, devices and identities with HP's hassle-free Client Security portfolio, including HP Drive Encryption, HP Device Access Manager with Just in Time Authentication, and HP Secure Erase.A fingerprint reader and integrated Smart Card Reader help keep your identity secure.
  • Productive powerhouse
    Get going in seconds with a solid-state drive. Enjoy the responsiveness of 4th generation Intel Dual-Core processors.Access the Internet and email in more places with optional integrated HP Mobile Broadband featuring 3G and 4G LTE.Use the optional HP UltraSlim Side Docking Station to connect to accessories and printers without the hassle of connecting individual components.Enjoy HP's new multi-gesture touchpad that allows you to use similar gestures as you would on a smart phone or tablet.Power through projects without worrying about recharging with up to 12 hours of battery life.
  • Durable and dependable
    The HP EliteBook Folio 1040 passes MIL-STD 810G testing for drop, functional shock, vibration, dust, humidity, altitude, high and low temperature, and temperature shock.
  • The power of touch
    Enjoy the intuitive control of the optional touchscreen that lets you make the most of Windows 8.1.
HP EliteBook Folio 1040 G1 - 14" - Intel Core i7 - 4600U - 8 GB RAM - 256 GB SSD - 3G
Ultrabook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Intel Core i7 (4th Gen) - 4600U / 2.1 GHz, up to 3.3 GHz / 4 MB Cache
8 GB DDR3L (1 x 4 GB + 4 GB (soldered))
Storage
256 GB SSD
Display
14" LED backlight Full HD UWVA eDP anti-glare+PSR 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 4400
Input Device
ForcePad
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
Wireless Broadband (WWAN)
3G
6-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
Platinum
33.8 cm x 23.35 cm x 1.59 cm
1.49 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - 3 years , Limited warranty - battery - 3 years
Ultrabook
Recommended Use
Small business, corporate business
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Processor / Chipset
CPU
Intel Core i7 (4th Gen) 4600U / 2.1 GHz
Max Turbo Speed
3.3 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Chipset
Intel QM87
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 4 GB + 4 GB (soldered))
Max RAM Supported
8 GB
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
256 GB SSD SATA 6Gb/s
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Full HD ultra wide-viewing angle (UWVA) eDP anti-glare +PSR
Audio & Video
Graphics Processor
Camera
Video Resolutions
1280 x 720
Sound
Stereo speakers, stereo microphone
Codec
IDT 92HD91
High Definition Audio, DTS Studio Sound, DTS SOUND+
Input
Keyboard, ForcePad
Keyboard Backlight
Volume control, spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-N 7260AN - PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I218-LM
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
Generation
3G
GSM, GPRS, EDGE, HSPA+
Controller
HP hs3110 - M.2 Card
Navigation
Receiver
GPS/A-GPS
6-cell lithium polymer
42 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
DisplayPort , Headphone/microphone combo jack , Dock , 2 x USB 3.0
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP ePrint, Device Access Manager, HP Wireless Hotspot (free download), HP Client Security, HP Mobile Connect, HP Secure Erase, Drive Encryption, HP Trust Circles Standard
Platinum
Case Material
Magnesium alloy
Dockable
Security
Charging via USB, HP DuraFinish, HP DuraKeys, HP DisplaySafe, HP SureStart, Full Volume Encryption
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, MIL-STD 810G, WEEE, A-Tick, ICES, KC, CIT
Localization
1.49 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance
40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance
0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
