Now employees can hit the road with a travel pro. The HP EliteBook 850 G1 industry leading Ultrabook is ultra-productive in and out of the office. Work with confidence thanks to proven enterprise technologies and enterprise security, performance and management features that will meet all your business needs.
Sleek and sturdy
It's time for an upgrade to the dramatically thin, light design of the HP EliteBook 850 G1 Ultrabook with a luxurious and soft touch finish.Join forces with the latest generation Intel architecture and operate at peak performance levels with Intel Smart Response Technology for disk cache and expand total storage options with an additional mini-card SSD.Dock up for an enterprise desktop experience using the optional UltraSlim Docking Station with a convenient side connector and dual DisplayPorts for multiple display support.Deliver graphics intensive projects right from your EliteBook with powerful AMD Radeon HD 8750M discrete graphics. -
It's all about the connections
Exercise full control over your wireless connections through a single user interface with support for most networks, including optional new 4G WWAN, using HP Connection Manager.Easily share your internet connection with up to five devices with HP Wireless Hotspot. Help colleagues get online and improve productivity.Take productivity to a whole new level with innovative software like HP ePrint and HP PageLift on the HP EliteBook 850 G1.Bridge distances on the HP EliteBook 800 series with Microsoft Lync, premium audio/video and optional full-HD display. -
Solid security
HP Sure Start restores productivity and reduces IT help desk calls in the event of a BIOS attack or corruption. Exclusively from HP, HP Sure Start helps reduce down time for users and IT.Stay up and running. HP BIOS Protection offers enhanced protection against virus attacks to the BIOS and other security threats, and is designed to help prevent data loss and reduce downtime.Safeguard data, devices and identities with HP's hassle-free Client Security portfolio, including HP Drive Encryption, HP Device Access Manager with Just In Time Authentication, and HP Secure Erase.Ensure smooth sailing with stable and consistent images, managed lifecycle transitions and Global Series support you can rely on. -
Road ready
Never fear accidental bumps and minor spills. HP EliteBooks undergo challenging tests so you don't have to. During the HP Total Test Process, PCs experience 115,000 hours of performance trials to ensure they can withstand rigorous work environments.Designed to be travel-tough, the HP EliteBook thin and light notebooks feature a new, soft touch finish and are designed to undergo MIL-STD 810G testing.
- HP EliteBook 850 G1 Notebook - 15.6" - Intel Core i7 4600U - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
- Processor
- Intel Core i7 (4th Gen) 4600U / 2.1 GHz (3.3 GHz) / 4 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Display
- 15.6" LED backlight HD SVA anti-glare 1366 x 768 / HD
- Graphics
- Intel HD Graphics 4400
- Input Device
- Pointing stick
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- 3-cell
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 37.5 cm x 25.3 cm x 2.142 cm
- 1.88 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Limited warranty - 3 years , Limited warranty - battery - 3 years
- Product Type
- Notebook
- Recommended Use
- Small business, corporate business
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 7200 rpm
Display
- 15.6" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- HD standard-viewing angle (SVA) anti-glare
Audio & Video
- Graphics Processor
- Camera
- Video Resolutions
- 1280 x 720
- Sound
- Stereo speakers, stereo microphone
- Codec
- IDT 92HD91
- High Definition Audio, DTS Studio Sound
Input
- Keyboard, touchpad, pointing stick
- Volume control, spill-resistant
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-N 7260AN
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 3-cell lithium polymer
- Capacity
- 50 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- 4 x USB 3.0 , DisplayPort , VGA , Headphone/microphone combo jack , LAN , Dock
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Cyberlink PowerDVD, HP Recovery Disc Creator, Microsoft Security Essentials, HP Connection Manager, HP ePrint, HP Hotkey Support, Absolute Data Protect, Drive Encryption for HP ProtectTools, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP Secure Erase, HP Trust Circles
- Case Material
- Magnesium-aluminum alloy
- Dockable
- Security
- Power-on password, HP Disk Sanitizer, HP Enhanced DriveLock, HP 3D DriveGuard, HP DuraKeys, Enhanced Pre-Boot Security, HP SpareKey, HP File Sanitizer, HP BIOS Protection, BIOS Absolute Persistence, USB 3.0 port power off USB charging
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, FCC Class B certified, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, cULus, KC
- Localization
- 1.88 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance
- 40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
- Vibration Tolerance
- 0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
