HP EliteBook 840 G6 Intel Core i7-8565U 8GB 256GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: FBR6WS00 Mfr#: 6XE69ET#ABU
  • Core i7
  • IEEE 802.11n
Uniquely designed for the modern mobile professional, the HP EliteBook 840 is a highly secure and manageable PC offering powerful collaboration tools, enabling the enterprise workforce to be more productive and secure on the go or in the office.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP.
  • High performance, high portability
    Help speed up demanding business applications with an 8th Gen quad-core Intel Core processor.
  • Fast and efficient wireless LAN
    Get gigabit speed Wi-Fi with Wi-Fi 6 (802.11ax).
  • Automatic recovery from firmware attacks
    Firmware attacks can completely devastate your PC. Stay protected with HP's self-healing BIOS - HP Sure Start Gen5 automatically recovers the BIOS from malware, rootkits, or corruption.
  • Protect critical security processes
    To get control of your PC, attackers first need to take down its defenses. Keep critical security protections up and running and prevent unwanted changes to security settings with HP Sure Run Gen2, which provides resilience against attacks.
  • Recovery simplified
    Advanced malware attacks can destroy your OS and disrupt your business. HP Sure Recover Gen2 ensures fast, secure, and automated recovery of your OS with only a network connection, so you can minimize downtime and get back to business fast.
HP EliteBook 840 G6 Notebook - 14" - Intel Core i7 8565U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) 8565U / 1.8 GHz (4.6 GHz) / 8 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - NVMe, TLC, HP Value + 32 GB SSD cache (PCIe (NVMe)) (3D Xpoint (Optane))
Display
14" WLED 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
Pointing stick, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac/ax, Gigabit Ethernet
3-cell - up to 17.25 hours
Ambient light sensor
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
32.6 cm x 23.43 cm x 1.79 cm
1.48 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4.6 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz / PC4-19200
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), triple-level cell (TLC), HP Value
SSD Cache
32 GB 3D Xpoint (Optane) (PCIe (NVMe))
Display
14" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
250 cd/m²
Colour Gamut
45% NTSC
Slim Design, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Keyboard Name
HP Premium Collaboration Keyboard
Audio & Video
Graphics Processor
Camera
Yes - HD
Camera Features
IR camera, HP Privacy HD
Sound
Stereo speakers, 3 multi-array microphone
Audio Features
Output: noise-cancellation technology, Bang & Olufsen Audio
Input
Keyboard, pointing stick, ClickPad
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-gesture clickpad
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 200
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Miracast, dual stream (2x2)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell lithium polymer
50 Wh
Run Time
Up to 17.25 hours
AC Adapter
Input
Output
65 Watt
Connections & Expansion
2 x USB 3.1 Gen 1 (charging) , USB-C (supports Thunderbolt) , HDMI , LAN , Dock , Headphone/microphone combo jack
Software
Software Included
HP Recovery Manager, HP Support Assistant, HP ePrint, HP Hotkey Support, HP Spare Key, Password Manager, Windows Defender, HP Velocity, HP Secure Erase, HP Security Manager, HP Client Catalog, HP Credential Manager, Absolute Persistence, HP BIOS Config Utility, HP Device Access Manager, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, Native Miracast, HP JetAdvantage, HP PhoneWise, HP Connection Optimizer, HP Sure Click, Power On Authentication, HP BIOSphere Gen5, HP Client Security Gen5
Case Material
Aluminum
Integrated Options
Dockable
Security
Power-on password, BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, MU-MIMO technology, Master Boot Record Security, HP Sure Run, HP Sure Recover, HP Wireless Wakeup, BIOS Update via Network, HP Sure Start Gen 5
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
USB-C power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT, low halogen, ICCP
Localization
1.48 kg
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Essential Accessories (7)
Get more from your purchase from one of our essential accessories
FBR6 HP 65W Smart AC Adapter In Stock £18.54
FBR6 HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack In Stock £13.44
FBR6 HP Dual Head Keyed Cable Lock In Stock £43.00
FBR6 HP USB-C mini Dock - Docking Station - USB-C - VGA, HDMI - GigE In Stock £33.61
FBR6 HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £147.06
FBR6 HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £206.71
FBR6 HP Travel Hub G2 Port replicator USB-C VGA, HDMI for Chromebook In Stock £41.06
Warranty Packs (8)
Protect your investment by taking out one of our great value warranty packs
FBR6 HP Care Pack Pick-Up and Return Service Extended Service Agreement 4 Years for EliteBook In Stock £107.13
FBR6 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site In Stock £94.03
FBR6 HP Care Pack NBD Hardware Support for Travelers with Defective Media Retention 3 Years On-Site In Stock £109.50
FBR6 HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site In Stock £104.74
FBR6 HP Care Pack Pick-Up and Return Service Extended Service Agreement 5 Years Pick-Up and Return In Stock £140.47
FBR6 HP EPACK 4 Year Onsite NBD+DMR (NB ONLY) In Stock £163.09
FBR6 HP 3 Year Premium Care Notebook service In Stock £144.46
FBR6 HP Carepack 5y Travel NextBusDay Notebook Only SVC In Stock £198.61
Other bundles (9)
FBR6 HPE HDMI to DVI Adapter In Stock £9.89
FBR6 HP USB-C To VGA Adapter In Stock £22.68
FBR6 HP USB Travel Mouse In Stock £10.14
FBR6 HP X4000b Bluetooth Mouse In Stock £28.71
FBR6 HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor In Stock £2,821.06
FBR6 HP Premium Wireless Mouse In Stock £38.00
FBR6 HP USB-C to DisplayPort Adapter In Stock £23.53
FBR6 HP USB-C to HDMI 2.0 Adapter In Stock £47.06
FBR6 HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor In Stock £144.44
