HP EliteBook 840 G6 Intel Core i5-8365U 8GB 256GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: FBR4WS00 Mfr#: 6XE68ET#ABU
Display Size: 14in
Processor Model: I5-8365U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
£1,115.74 ex VAT
£1,338.88 inc VAT
Uniquely designed for the modern mobile professional, the HP EliteBook 840 is a highly secure and manageable PC offering powerful collaboration tools, enabling the enterprise workforce to be more productive and secure on the go or in the office.
  • Brilliant design
    Balance design, power, and mobility with this ultraslim distinctively designed aluminum laptop with a narrow border display. This light and compact PC is built for the professional who requires top performance while on the go.
  • Built on a secure foundation
    Protect your PC against the evolving malware threats of the future, with self-healing, hardware-enforced, manageable security solutions from HP. From the BIOS to the browser HP Sure Start Gen5 and HP Sure Click help secure your PC.
  • Crystal-clear collaboration
    Calls sound clear and crisp with advanced collaboration features like HP Noise Cancellation. Loud top-firing speakers produce rich sound. The world-facing third microphone and collaboration keys help make PC calls productive.
HP EliteBook 840 G6 - 14" - Core i5 8365U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Platform Technology
Intel vPro Technology
Intel Core i5 (8th Gen) 8365U / 1.6 GHz (4.1 GHz) / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - NVMe, HP Value
Optical Drive
No optical drive
Display
14" WLED 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
Pointing stick, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac/ax, Gigabit Ethernet
3-cell
Ambient light sensor
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
32.6 cm x 23.43 cm x 1.79 cm
1.48 kg
Environmental Standards
TCO Certified Notebooks 8, ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
Quad-Core
Cache
L3 - 6 MB
64-bit Computing
Platform Technology
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz / PC4-19200
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), HP Value
Display
14" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
250 cd/m²
Bezel Type
Raised
45% NTSC colour gamut, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Keyboard Name
HP Premium Collaboration Keyboard
Audio & Video
Graphics Processor
Camera
Yes - HD
Video Resolutions
720p
Camera Features
IR camera
Sound
Stereo speakers, 3 multi-array microphone
Audio Features
Noise-cancellation technology, Bang & Olufsen Audio
Input
Keyboard, pointing stick, ClickPad
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-gesture clickpad
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 200
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Miracast, dual stream (2x2)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell Lithium Ion
50 Wh
AC Adapter
Input
Output
65 Watt
Connections & Expansion
USB 3.1 Gen 1 (charging) , USB 3.1 Gen 1 , USB-C/Thunderbolt , HDMI , LAN , Dock , Headphone/microphone combo jack
Software
Software Included
HP Recovery Manager, HP Support Assistant, HP ePrint, HP Hotkey Support, HP Spare Key, Password Manager, Windows Defender, HP Velocity, HP Secure Erase, HP Security Manager, HP Client Catalog, HP Credential Manager, Absolute Persistence, HP BIOS Config Utility, HP Device Access Manager, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, Native Miracast, HP JetAdvantage, HP PhoneWise, HP Connection Optimizer, HP Sure Click, Power On Authentication, HP BIOSphere Gen5, HP Client Security Gen5
Case Material
Aluminum
Integrated Options
Dockable
Security
Power-on password, BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, MU-MIMO technology, Master Boot Record Security, HP Sure Run, HP Sure Recover, HP Wireless Wakeup, BIOS Update via Network, HP Sure Start Gen 5
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, Common Criteria EAL4+, KC, CIT, low halogen, ICCP
Localization
1.48 kg
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Display Size: 14in
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Touchscreen: No
Type: Laptop
Brand: HP
Price Range Ex VAT: 1000 - 1500
