HP EliteBook 840 G5 Core i7-8550U 8GB 256GB SSD 14"  Windows 10 Pro
Quicklinx: DQ84WS00 Mfr#: 3UP81ET#ABU
Display Size: 14in
Processor Model: I7-8550U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i7
  • IEEE 802.11n
45 in stock
£1,258.67 ex VAT
£1,510.40 inc VAT
Beautifully crafted with the modern professional in mind, the highly secure and manageable HP EliteBook 840 offers powerful collaboration tools, so you can be as productive as ever, on the go or at the office.
  • Brilliant new design
    This ultra-slim, precision-crafted aluminum laptop with a narrow border display goes anywhere, and looks great doing it. An optional ultra-bright display adapts to any environment, for an optimal viewing experience wherever you work.
  • Built on a secure foundation
    Protect your PC against the evolving malware threats of the future, with self-healing, hardware-enforced, and manageable security solutions from HP. From the BIOS to the browser HP Sure Start Gen4 and HP Sure Click help secure your PC.
  • Crystal-clear collaboration
    Calls sound crisp and clear with advanced collaboration features like HP Noise Cancellation. Loud top-firing speakers produce rich sound. The world-facing third microphone and collaboration keys help make PC calls productive.
  • A modern docking solution
    Quickly transition to desktop productivity with a single USB-C -cable. The optional HP Thunderbolt Dock G2 delivers enterprise manageability and an optional audio module. Traditional side docking is also supported to work with your existing solution.
HP EliteBook 840 G5 - 14" - Core i7 8550U - 8 GB RAM - 256 GB SSD - QWERTY UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) 8550U / 1.8 GHz (4 GHz) / 8 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB - M.2 2280 SSD NVMe, TLC
Optical Drive
No optical drive
Display
14" WLED 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
Pointing stick, ClickPad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell - up to 14 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip
32.6 cm x 23.4 cm x 1.79 cm
1.48 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Intel Turbo Boost Technology
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz / PC4-19200 - 2400 MHz
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe - NVM Express (NVMe), triple-level cell (TLC)
Display
14" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
220 cd/m²
Full HD anti-glare
Keyboard Name
HP Premium Collaboration Keyboard
Audio & Video
Graphics Processor
Camera
Yes - HD
Sound
Stereo speakers, 3 multi-array microphone
Audio Features
Noise-cancellation technology, Bang & Olufsen Audio
Input
Keyboard, pointing stick, ClickPad
Keyboard Layout
QWERTY UK
Volume control, spill-resistant, multi-touch clickpad, multi-gesture clickpad
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Dual stream (2x2)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell lithium polymer
50 Wh
Run Time
Up to 14 hours
AC Adapter
Input
Output
45 Watt
Connections & Expansion
USB 3.1 Gen 1 (charging) , USB 3.1 Gen 1 , USB-C/Thunderbolt , HDMI , LAN , Dock , Headphone/microphone combo jack
Software
Software Included
HP Recovery Manager, HP Support Assistant, HP ePrint, HP Hotkey Support, HP Spare Key, Password Manager, Windows Defender, HP Velocity, HP Secure Erase, HP Security Manager, HP Drive Packs (free download), HP Client Catalog, HP Credential Manager, Absolute Persistence, HP BIOS Config Utility, HP Device Access Manager, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, Native Miracast, HP JetAdvantage, HP PhoneWise, HP Connection Optimizer, HP Sure Click, HP BIOSphere Gen4, HP Manageability & Integration Kit Gen2, Ivanti Management Suite (subscription required), HP Client Security Suite Gen4, Power On Authentication
Case Material
Aluminum
Dockable
Security
Power-on password, BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, Master Boot Record Security, HP Sure Start Gen 4, HP Sure Run, HP Sure Recover, HP Wireless Wakeup, BIOS Update via Network
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT, low halogen, TCO Certified Notebooks 5.0, ICCP
Localization
1.48 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP EliteBook 840 G5 Core i7-8550U 8GB 256GB SSD 14 Bundle deal on HP EliteBook 840 G5 Core i7-8550U 8GB 256GB SSD 14" Windows 10 Pro
£1,446.31
saving £8.33
£1,358.43
Display Size: 14in
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Type: Laptop
Brand: HP
Price Range Ex VAT: 1000 - 1500
