HP EliteBook 840 G4 Core i7-7500U 8GB 256GB SSD 14" Windows 10 Pro
Quicklinx: CN3KWS00 Mfr#: Z2V60ET#ABU
  • Core i7
  • IEEE 802.11n
Elevate your business with an ultrathin, professional laptop that empowers users to perform at their very best. Enterprise-class features, comprehensive security, and a refined collaboration experience handle even the most demanding tasks with streamlined efficiency.
Security inside and out
Get end-to-end protection from HP’s most secure and manageable PCs. The optional HP Sure View integrated privacy screen keeps visual hackers in the dark with the touch of a button while HP Sure Start Gen3 protects against BIOS attacks.
High performance, high portability
Speed up demanding business applications and data. Combine high-performance and long battery life with 7th Gen Intel® Core™ processors, and PCIe Gen3 solid state drives. Amplify performance with up to 32 GB of DDR4 memory and dual storage options.
Thin design, no adapters needed
Give portability a whole new meaning with an ultrathin design that doesn’t cut corners. Starting at an incredible 18.9mm, the HP EliteBook 840 includes several full-size ports like VGA, DisplayPort™, RJ-45, and enterprise docking.
See and hear them clearly
Give your online collaboration the sharpness and clarity of a face-to-face meeting with HP Audio Boost, HP Noise Cancellation software, Audio by Bang & Olufsen, and an optional 720p webcam4.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful, sleek, thin, and light HP EliteBook 840.
  • Self-healing safeguard
    HP Sure Start Gen3 monitors in-memory BIOS, recovers the platform without intervention, restores the BIOS to a custom state, and is enterprise ready for centralized management.
  • Get PC images right the first time
    Improve the quality and security of custom Windows images with HP Image Assistant which assists ITDMs with image creation, identifies problems, and provides recommendations and remediation.
  • Speed up the basics of IT management
    Deploy the HP Manageability Integration Kit to help speed up image creation and the management of hardware, BIOS, and security when managing devices through Microsoft SCCM.
  • Charge faster
    Get up to 50% battery life in just 30 minutes of charging with an HP fast charging battery.
HP EliteBook 840 G4 Notebook - 14" - Intel Core i7 - 7500U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (7th Gen) - 7500U / 2.7 GHz, up to 3.5 GHz / 4 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - HP Z Turbo Drive
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell - up to 15.25 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
33.8 cm x 23.7 cm x 1.89 cm
1.48 kg
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i7 (7th Gen) 7500U / 2.7 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD PCIe - HP Z Turbo Drive
Display
14" - TN
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Slim Design, Full HD standard-viewing angle (SVA) eDP anti-glare
Keyboard Name
HP Premium
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 720p
Sound
Stereo speakers, two microphones
Codec
CX7501
Audio Features
Output: noise-cancellation technology, Bang & Olufsen Audio, HP Clear Sound Amp
Input
Keyboard, touchpad
Keyboard Layout
Touchpad with gesture support
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell Lithium Ion
51 Wh
Run Time
Up to 15.25 hours
AC Adapter
Input
Output
45 Watt
Connections & Expansion
Slots
1 x SIM card (1 free)
Interfaces Details
USB 3.1 Gen 1 , USB 3.1 Gen 1 (charging) , USB-C , DisplayPort , VGA , LAN , Dock , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Skype, LANDesk Management Suite, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Systems Software Manager, Password Manager, HP Client Security, HP Velocity, HP Secure Erase, HP BIOSphere, HP Client Catalog, HP BIOS Config Utility, HP Device Access Manager, HP 3D DriveGuard, HP Mobile Connect Pro, HP Image Assistant, HP JetAdvantage Connect, HP Workwise
Dockable
Security
BIOS Absolute Persistence, Pre-boot Authentication, HP Sure Start Gen 3
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Localization
1.48 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
