Impressively thin and light, the HP EliteBook 840 empowers users to create, connect, and collaborate, using enterprise-class performance technology that helps keep you productive in and out of the office.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful, sleek, thin, and light HP EliteBook 840. -
Self-healing safeguard
HP Sure Start with Dynamic Protection checks your BIOS every 15 minutes to detect attacks and corruption then self-heals the BIOS automatically. -
Give your fingers a break
Enjoy a remarkable balance of comfort and feedback with the HP Premium Keyboard engineered for accuracy. -
Storage options galore
Get the speed and space you need without having to use external storage. Dual drive support options quickly boot, wake, and run your system on a fast SSD and let you maintain access to your files with a high-capacity HDD. -
Field ready
Stand up to the workload with an EliteBook that passed MIL-STD 810G testing. -
In-house serviceability
Expand your system's memory, battery, storage, and WWAN components.
- HP EliteBook 840 G3 Notebook - 14" - Intel Core i7 - 6500U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Processor
- Intel Core i7 (6th Gen) - 6500U / 2.5 GHz, up to 3.1 GHz / 4 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 520
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 3-cell - up to 13.5 hours
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 33.8 cm x 23.7 cm x 1.89 cm
- 1.6 kg
- Localisation
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6500U / 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 SATA 6Gb/s
Display
- 14" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Slim Design, Full HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 1280 x 720
- Sound
- Stereo speakers, two microphones
- Codec
- CX7501
- HP Clear Sound Amp
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Volume control, spill-resistant
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
- Remote Management Protocol
- SNMP 2
- Wake-on-LAN (WOL)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 3-cell lithium polymer
- Capacity
- 46 Wh
- Run Time
- Up to 13.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Slots
- 1 x SIM card (1 free)
- Interfaces Details
- USB-C , 2 x USB 3.0 , DisplayPort , VGA , LAN , Dock , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Drivers & Utilities, Cyberlink PowerDVD, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, Drive Encryption, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP Pixel Sharp, HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard, HP Noise Reduction Software
- Case Material
- Aluminum, magnesium alloy
- Dockable
- Security
- HP DuraKeys, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, 1 USB 3.0 charging port, Pre-boot Authentication
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, RoHS, WEEE
- Localization
- 1.6 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
