Impressively thin and light, the HP EliteBook 840 empowers users to create, connect, and collaborate, using enterprise-class performance technology that helps keep you productive in and out of the office.
Portable powerhouse
Combine high performance technology and long battery life with Windows 10 Pro, 6th Gen Intel® Core™ processors, and a PCIe Gen3 SSD. Drive performance with up to 32 GB of DDR4 memory, and dual storage options for your most demanding business applications and fast access to data.
Slim new design with all the right ports
Connect to essential ports without the hassle of dongles. At just 18.9 mm, the ultraslim and light HP EliteBook 840 comes with VGA, Display Port, RJ-45, USB, USB-C™, and enterprise docking capabilities.
Security inside and out
HP helps protect you from malware and visual hacking. HP Sure Start with Dynamic Protection protects against BIOS attacks, and the optional HP Sure View integrated privacy screen5 shields your screen from prying eyes with the touch of a button.
Designed for collaboration
Replace your speaker phone with the HP EliteBook 840 with Audio by Bang & Olufsen plus HP Noise Reduction Software that provides a rich collaboration experience for applications like Skype for Business.
- HP EliteBook 840 G3 Notebook - 14" - Core i5 6200U - 500 GB
- Product Type
- Notebook
- Processor
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz (2.8 GHz)
- Memory
- DDR4
- Storage
- 500 GB
- Display
- 14" LED backlight
- Graphics
- Intel HD Graphics 520
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 3-cell
- Dockable
- Security
- Smart card reader
- 33.8 cm x 23.7 cm x 1.89 cm
- Localisation
- Product Type
- Notebook
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
Storage
- Main Storage
- 500 GB
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Widescreen
Audio & Video
- Graphics Processor
- Sound
- Stereo speakers, two microphones
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard, touchpad
- Spill-resistant
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Remote Management Protocol
- SNMP 2
- IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11i, IEEE 802.3az
- Technology
- 3-cell
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
- Case Material
- Aluminum, magnesium alloy
- Dockable
- Security
- Smart card reader
- Security lock slot (cable lock sold separately), HP BIOS Protection, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Pre-boot Authentication
- Included Accessories
- Power adapter
- RoHS
- Localization
