HP EliteBook 840 G3 14" Intel Core i5 6200U 4 GB RAM 500 GB Windows 10 Pro
Quicklinx: CKJ9WS00 Mfr#: Z2X13ES#ABU
  • Core i5
  • IEEE 802.11n
Impressively thin and light, the HP EliteBook 840 empowers users to create, connect, and collaborate, using enterprise-class performance technology that helps keep you productive in and out of the office.
Portable powerhouse
Combine high performance technology and long battery life with Windows 10 Pro, 6th Gen Intel® Core™ processors, and a PCIe Gen3 SSD. Drive performance with up to 32 GB of DDR4 memory, and dual storage options for your most demanding business applications and fast access to data.
Slim new design with all the right ports
Connect to essential ports without the hassle of dongles. At just 18.9 mm, the ultraslim and light HP EliteBook 840 comes with VGA, Display Port, RJ-45, USB, USB-C™, and enterprise docking capabilities.
Security inside and out
HP helps protect you from malware and visual hacking. HP Sure Start with Dynamic Protection protects against BIOS attacks, and the optional HP Sure View integrated privacy screen5 shields your screen from prying eyes with the touch of a button.
Designed for collaboration
Replace your speaker phone with the HP EliteBook 840 with Audio by Bang & Olufsen plus HP Noise Reduction Software that provides a rich collaboration experience for applications like Skype for Business.
HP EliteBook 840 G3 Notebook - 14" - Core i5 6200U - 500 GB
Notebook
Intel Core i5 (6th Gen) 6200U / 2.3 GHz (2.8 GHz)
DDR4
Storage
500 GB
Display
14" LED backlight
Graphics
Intel HD Graphics 520
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell
Dockable
Security
Smart card reader
33.8 cm x 23.7 cm x 1.89 cm
Notebook
Processor / Chipset
CPU
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
64-bit Computing
Intel Turbo Boost Technology 2.0
DDR4 SDRAM
Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Storage
Main Storage
500 GB
Display
14"
LCD Backlight Technology
LED backlight
Widescreen
Audio & Video
Graphics Processor
Sound
Stereo speakers, two microphones
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard, touchpad
Spill-resistant
Communications
Wireless
Network Interface
Gigabit Ethernet
Remote Management Protocol
SNMP 2
IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11i, IEEE 802.3az
3-cell
AC Adapter
Input
Output
45 Watt
Connections & Expansion
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Case Material
Aluminum, magnesium alloy
Dockable
Security
Smart card reader
Security lock slot (cable lock sold separately), HP BIOS Protection, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Pre-boot Authentication
Power adapter
RoHS
Localization
