HP EliteBook 840 G2 Intel Core i7-5500U 4GB 500GB 14" Windows 7 Professional 64-bit
Quicklinx: BHS0WS00 Mfr#: J8R51EA#ABU
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
The HP EliteBook 840 thin and light notebook allows users to be ultra-productive in and out of the office. Work with confidence thanks to proven technologies, security, performance, and management features that will meet all your enterprise needs.
  • The simplicity of touch
    Enjoy the intuitive control of Windows 8.1 and impressive clarity of the optional FHD touchscreen featuring tough Corning Gorilla Glass 3.
  • Storage options galore
    The latest storage options, including PCIeSSD, ensure optimum performance from your HP EliteBook.
  • Crisp, clear view
    Experience great visual performance with optional AMD discrete graphics on optional FHD displays.
  • Effortless manageability
    Enjoy easy integration with HP Touchpoint Manager, HP Client Management Solutions and Intel vPro technology.
  • Customized protection
    HP BIOSphere keeps mission-critical data and systems protected with customizable security.
  • Self-healing safeguard
    HP Sure Start detects corruption and self-heals the BIOS.
HP EliteBook 840 G2 Notebook - 14" - Intel Core i7 - 5500U - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Intel Core i7 (5th Gen) - 5500U / 2.4 GHz, up to 3 GHz / 4 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 5500
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
3-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
33.9 cm x 23.7 cm x 2.1 cm
1.55 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years , Limited warranty - battery - 3 years
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Processor / Chipset
CPU
Intel Core i7 (5th Gen) 5500U / 2.4 GHz
Max Turbo Speed
3 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 3Gb/s / 7200 rpm
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Full HD ultra wide-viewing angle (UWVA) anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 1280 x 720
Sound
Stereo speakers, stereo microphone
High Definition Audio, DTS Studio Sound
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7265 - PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I218-LM
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell lithium polymer
Installed Qty
1
Max Supported Qty
2
50 Wh
AC Adapter
Input
Output
45 Watt
Connections & Expansion
DisplayPort , 4 x USB 3.0 , LAN , Dock , Headphone/microphone combo jack , Battery
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Cyberlink PowerDVD, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, HP Mobile Connect, HP Systems Software Manager (free download), HP PageLift, HP UEFI System Diagnostics, HP Wireless Hotspot, Getting Started guide with Windows 8, HP GPS and Location, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Client Security Manager, HP Driver Packs, LANDesk Management Suite (free download), HP Device Access Manager
Case Material
Magnesium-aluminum alloy
Dockable
Security
Power-on password, HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP DuraKeys, HP SpareKey, HP File Sanitizer, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Measured Boot, Power On Authentication, Pre-Boot Security, HP Roaming Alert, Intel My WiFi Technology, 1 USB 3.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT
Localization
1.55 kg
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
