The HP EliteBook 840 thin and light notebook allows users to be ultra-productive in and out of the office. Work with confidence thanks to proven technologies, security, performance, and management features that will meet all your enterprise needs.
The simplicity of touch
Enjoy the intuitive control of Windows 8.1 and impressive clarity of the optional FHD touchscreen featuring tough Corning Gorilla Glass 3. -
Storage options galore
The latest storage options, including PCIeSSD, ensure optimum performance from your HP EliteBook. -
Crisp, clear view
Experience great visual performance with optional AMD discrete graphics on optional FHD displays. -
Effortless manageability
Enjoy easy integration with HP Touchpoint Manager, HP Client Management Solutions and Intel vPro technology. -
Customized protection
HP BIOSphere keeps mission-critical data and systems protected with customizable security. -
Self-healing safeguard
HP Sure Start detects corruption and self-heals the BIOS.
- HP EliteBook 840 G2 Notebook - 14" - Intel Core i7 - 5500U - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
- Processor
- Intel Core i7 (5th Gen) - 5500U / 2.4 GHz, up to 3 GHz / 4 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 5500
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 3-cell
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 33.9 cm x 23.7 cm x 2.1 cm
- 1.55 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years , Limited warranty - battery - 3 years
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Processor / Chipset
- CPU
- Intel Core i7 (5th Gen) 5500U / 2.4 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 7200 rpm
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Full HD ultra wide-viewing angle (UWVA) anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 1280 x 720
- Sound
- Stereo speakers, stereo microphone
- High Definition Audio, DTS Studio Sound
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Volume control, spill-resistant, touchpad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - PCI Express Half Mini Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 3-cell lithium polymer
- Installed Qty
- 1
- Max Supported Qty
- 2
- Capacity
- 50 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- DisplayPort , 4 x USB 3.0 , LAN , Dock , Headphone/microphone combo jack , Battery
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Cyberlink PowerDVD, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, HP Mobile Connect, HP Systems Software Manager (free download), HP PageLift, HP UEFI System Diagnostics, HP Wireless Hotspot, Getting Started guide with Windows 8, HP GPS and Location, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Client Security Manager, HP Driver Packs, LANDesk Management Suite (free download), HP Device Access Manager
- Case Material
- Magnesium-aluminum alloy
- Dockable
- Security
- Power-on password, HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP DuraKeys, HP SpareKey, HP File Sanitizer, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Measured Boot, Power On Authentication, Pre-Boot Security, HP Roaming Alert, Intel My WiFi Technology, 1 USB 3.0 charging port
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT
- Localization
- 1.55 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
