The HP EliteBook 840 thin and light notebook allows users to be ultra-productive in and out of the office. Work with confidence thanks to proven technologies, security, performance, and management features that will meet all your enterprise needs.
The simplicity of touch
Enjoy the intuitive control of Windows 8.1 and impressive clarity of the optional FHD touchscreen featuring tough Corning Gorilla Glass 3. -
Storage options galore
The latest storage options, including PCIeSSD, ensure optimum performance from your HP EliteBook. -
Crisp, clear view
Experience great visual performance with optional AMD discrete graphics on optional FHD displays. -
Effortless manageability
Enjoy easy integration with HP Touchpoint Manager, HP Client Management Solutions and Intel vPro technology. -
Customized protection
HP BIOSphere keeps mission-critical data and systems protected with customizable security. -
Self-healing safeguard
HP Sure Start detects corruption and self-heals the BIOS.
- HP EliteBook 840 G2 Notebook - 14" - Intel Core i5 - 5200U - 4 GB RAM - 1 TB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
- Processor
- Intel Core i5 (5th Gen) - 5200U / 2.2 GHz, up to 2.7 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 1 TB HDD / 7200 rpm + 32 GB SSD cache (M.2)
- Display
- 14" LED backlight 1600 x 900 / HD+
- Graphics
- Intel HD Graphics 5500
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, NFC, Gigabit Ethernet
- Battery
- 3-cell - up to 12.25 hours
- Dockable
- Security
- Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader
- 33.9 cm x 23.7 cm x 2.1 cm
- 1.55 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Processor / Chipset
- CPU
- Intel Core i5 (5th Gen) 5200U / 2.2 GHz
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 1 TB HDD SATA 3Gb/s / 7200 rpm
- SSD Cache
- 32 GB (M.2)
Display
- 14" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1600 x 900 (HD+)
- Widescreen
- HD+ standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Camera Features
- 720p HD movie recording
- Sound
- Stereo speakers, two microphones
- Codec
- Realtek ALC3228
- High Definition Audio, DTS Studio Sound
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Volume control, spill-resistant, touchpad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 7265
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 3-cell lithium polymer
- Installed Qty
- 1
- Max Supported Qty
- 2
- Capacity
- 50 Wh
- Run Time
- Up to 12.25 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- DisplayPort , 4 x USB 3.0 , LAN , Dock , Battery , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Cyberlink PowerDVD, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP ePrint, HP Device Manager, HP Hotkey Support, CyberLink YouCam BE, Foxit PhantomPDF Express, HP Client Security, HP PageLift, HP Secure Erase, Intel My WiFi, HP Client Security Manager, HP Roaming Alert
- Case Material
- Aluminum, magnesium alloy
- Dockable
- Security
- HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP DuraKeys, HP SpareKey, HP File Sanitizer, HP DuraCase, HP BIOS Protection, UEFI BIOS, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT
- Localization
- 1.55 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
