Ease through your multi-task, multi-place day with the beautifully designed, powerful, highly secure HP EliteBook 835. Created for people on the move, this thin and light laptop helps people confidently connect and stay productive in almost any setting.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP. -
Keep business moving forward
Work with a powerful, highly secure, and reliable AMD Ryzen PRO processor with Radeon VEGA graphics and AMD Memory Guard that helps defend against cold boot attacks with real-time encryption and decryption of your system's memory. -
HP Sure Sense
Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware. -
Fast and efficient wireless LAN
The portability of your PC and the reliability of a fast connection determines where you can work. Get a fast and reliable connection in dense wireless environments with gigabit-speed Wi-Fi 6. -
Automatic recovery from firmware attacks
Firmware attacks can completely devastate your PC. Stay protected with HP's self-healing BIOS - HP Sure Start Gen6 automatically recovers the BIOS from malware, rootkits, or corruption. -
Keep your PC's security protections in place
Stop unwanted changes to security settings and help limit the spread of malware with HP Sure Run Gen3 which identifies, quarantines, and provides reporting on attackers trying to kill processes.
- HP EliteBook 835 G7 Notebook - 13.3" - Ryzen 5 Pro 4650U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- AMD Ryzen 5 Pro 4650U / 2.1 GHz (4 GHz) / 8 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - NVMe, HP Value
- Display
- 13.3" WLED 1920 x 1080 / Full HD
- Graphics
- AMD Radeon Graphics
- Input Device
- ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11a/b/g/n/ac/ax
- Battery
- 3-cell
- Hall sensor
- Security
- Trusted Platform Module (TPM 1.2) and firmware (TPM 2.0), fingerprint reader, smart card reader
- 30.78 cm x 20.46 cm x 1.79 cm
- 1.26 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 4 GHz
- Number of Cores
- 6-core
- Cache
- L3 - 8 MB
- 64-bit Computing
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 3200 MHz
- Rated Speed
- 3200 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe 3.0 x4 - NVM Express (NVMe), HP Value
Display
- 13.3" - IPS
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 45% NTSC
- Anti-glare
- Keyboard Name
- HP Premium
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Camera Features
- Privacy shutter, IR camera, Windows Hello
- Sound
- Stereo speakers, 3 multi-array microphone
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Spill-resistant, multi-touch clickpad, gesture function, glass clickpad, DuraKeys
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Wi-Fi 6 AX 200
- Miracast, dual stream (2x2), MU-MIMO
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 3-cell Lithium Ion
- Capacity
- 53 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V
Connections & Expansion
- Headphone/microphone combo jack , USB 3.1 Gen 1 , USB 3.1 Gen 1 (charging) , HDMI , 2 x USB-C 3.1 Gen 2 (Alternate Mode)
Software
- Software Included
- HP Support Assistant, HP Hotkey Support, Windows Defender, HP JumpStart, HP Noise Cancellation, HP Connection Optimizer, HP Sure Click, HP Fingerprint Sensor, HP BIOSphere Gen5, HP Sure Sense, HP Sure Recover Gen3, HP Client Security Manager Gen6, HP SureStart Gen6, HP Sure Run Gen3
- Integrated Options
- Hall sensor
- Security
- Power-on password, Setup Password, BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, BIOS Update via Network, HP Secure Erase
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- Power adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, Common Criteria EAL4+, KC, CIT, ICCP
- Localization
- 1.26 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (5)
Get more from your purchase from one of our essential accessories
HP 65W Smart AC Adapter | In Stock | £18.31 |
HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack | In Stock | £13.44 |
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £147.06 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £206.71 |
HP Travel Hub G2 Port replicator USB-C VGA, HDMI for Chromebook | In Stock | £41.06 |
Warranty Packs (8)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack Pick-Up and Return Service Extended Service Agreement 4 Years for EliteBook | In Stock | £107.13 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site | In Stock | £94.03 |
HP Care Pack NBD Hardware Support for Travelers with Defective Media Retention 3 Years On-Site | In Stock | £109.50 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site | In Stock | £104.74 |
HP Care Pack Pick-Up and Return Service Extended Service Agreement 5 Years Pick-Up and Return | In Stock | £140.47 |
HP EPACK 4 Year Onsite NBD+DMR (NB ONLY) | In Stock | £163.09 |
HP 3 Year Premium Care Notebook service | In Stock | £144.46 |
HP Carepack 5y Travel NextBusDay Notebook Only SVC | In Stock | £198.61 |
Other bundles (7)
HP USB-C To VGA Adapter | In Stock | £22.68 |
HP USB Travel Mouse | In Stock | £10.14 |
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP Premium Wireless Mouse | In Stock | £38.00 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £47.06 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £144.44 |
