Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP. -
High performance, high portability
Help speed up demanding business applications with an 8th Gen quad-core Intel Core processor. -
Fast and efficient wireless LAN
Get gigabit speed Wi-Fi with Wi-Fi 6 (802.11ax). -
Automatic recovery from firmware attacks
Firmware attacks can completely devastate your PC. Stay protected with HP's self-healing BIOS - HP Sure Start Gen5 automatically recovers the BIOS from malware, rootkits, or corruption. -
Preserve your privacy
Never wonder if someone is watching you with the added peace-of-mind that comes from the integrated HP Privacy Camera, with a physical shutter to protect from malicious surveillance. -
Protect critical security processes
To get control of your PC, attackers first need to take down its defenses. Keep critical security protections up and running and prevent unwanted changes to security settings with HP Sure Run Gen2, which provides resilience against attacks.
- HP EliteBook 830 G6 Notebook - 13.3" - Intel Core i7 8565U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (8th Gen) 8565U / 1.8 GHz (4.6 GHz) / 8 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - NVMe, HP Value
- Display
- 13.3" WLED HP SureView 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11a/b/g/n/ac/ax, Gigabit Ethernet
- Battery
- 3-cell
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- 31.04 cm x 22.93 cm x 1.77 cm
- 1.33 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.6 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), HP Value
Display
- 13.3" - IPS
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 1000 cd/m²
- Colour Gamut
- 72% NTSC
- Privacy Technology
- HP SureView
- Ambient light sensor, Full HD eDP anti-glare, 72% NTSC colour gamut
- Keyboard Name
- HP Premium Collaboration Keyboard
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Camera Features
- IR camera
- Sound
- Stereo speakers, 3 multi-array microphone
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Numeric Keypad
- Volume control, spill-resistant, multi-touch clickpad, multi-gesture clickpad
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Wi-Fi 6 AX 200
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
- Dual stream (2x2)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 3-cell Lithium Ion
- Capacity
- 50 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- USB 3.1 Gen 1 (charging) , USB 3.1 Gen 1 , USB-C (supports Thunderbolt) , HDMI , LAN , Dock , Headphone/microphone combo jack
- Case Material
- Aluminum
- Dockable
- Security
- Power-on password, BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, MU-MIMO technology, Master Boot Record Security, HP Sure Run, HP Sure Recover, BIOS Update via Network
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- USB-C power adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT, low halogen, ICCP
- Localization
- 1.33 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (6)
Get more from your purchase from one of our essential accessories
HP 65W Smart AC Adapter | In Stock | £18.54 |
HP Dual Head Keyed Cable Lock | In Stock | £43.00 |
HP USB-C mini Dock - Docking Station - USB-C - VGA, HDMI - GigE | In Stock | £33.61 |
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £147.06 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £206.71 |
HP Travel Hub G2 Port replicator USB-C VGA, HDMI for Chromebook | In Stock | £41.06 |
Warranty Packs (8)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack Pick-Up and Return Service Extended Service Agreement 4 Years for EliteBook | In Stock | £107.13 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site | In Stock | £94.03 |
HP Care Pack NBD Hardware Support for Travelers with Defective Media Retention 3 Years On-Site | In Stock | £109.50 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site | In Stock | £104.74 |
HP Care Pack Pick-Up and Return Service Extended Service Agreement 5 Years Pick-Up and Return | In Stock | £140.47 |
HP EPACK 4 Year Onsite NBD+DMR (NB ONLY) | In Stock | £163.09 |
HP 3 Year Premium Care Notebook service | In Stock | £144.46 |
HP Carepack 5y Travel NextBusDay Notebook Only SVC | In Stock | £198.61 |
Other bundles (10)
HPE DisplayPort to HDMI Adapter | In Stock | £13.44 |
HPE HP DisplayPort to DVI Adapter | In Stock | £17.23 |
HP USB-C To VGA Adapter | In Stock | £22.68 |
HP USB Travel Mouse | In Stock | £10.14 |
HP X4000b Bluetooth Mouse | In Stock | £28.71 |
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP Premium Wireless Mouse | In Stock | £38.00 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £47.06 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £144.44 |
