HP EliteBook 820 G3 Intel Core i5 6200U 8GB 256GB 12.5" W10P
Quicklinx: CTCBWS00 Mfr#: Y3B65EA#ABU
Display Size: 12.5in
Processor Model: I5-6200U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB, 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
30 in stock
£1,084.73 ex VAT
£1,301.67 inc VAT
Impressively thin and light, the HP EliteBook 820 empowers users to create, connect, and collaborate, using enterprise-class performance technology that helps keep you productive in and out of the office.
Portable powerhouse
Combine high performance technology and long battery life with Windows 10 Pro, 6th Gen Intel® Core™ processors, and a PCIe Gen3 SSD. Unlock next generation memory performance with DDR4 memory for your most demanding business applications.
Slim new design with all the right ports
Connect to essential ports you need without the hassle of dongles. At just 18.9 mm, the ultraslim and light HP EliteBook 820 comes with VGA, Display Port, RJ-45, USB, USB-C™, and enterprise docking capabilities.
Strong security, powerful manageability
Protect, detect, and recover from malicious attacks with HP Sure Start with Dynamic Protection - the industry’s first self-healing BIOS that monitors and corrects BIOS corruption every 15 minutes.
Designed for collaboration
Replace your speaker phone with the HP EliteBook 820 with Audio by Bang & Olufsen plus HP Noise Reduction Software that provides a rich collaboration experience for applications like Skype for Business.
  • Portable powerhouse
    Combine high performance technology and long battery life with Windows 10 Pro, 6th Gen Intel Core processors, and a PCIe Gen3 SSD. Unlock next generation memory performance with DDR4 memory for your most demanding business applications.
  • Slim new design with all the right ports
    Connect to essential ports you need without the hassle of dongles. At just 18.9 mm, the ultraslim and light HP EliteBook 820 comes with VGA, Display Port, RJ-45, USB, USB-C , and enterprise docking capabilities.
  • Strong security, powerful manageability
    Protect, detect, and recover from malicious attacks with HP Sure Start with Dynamic Protection - the industry's first self-healing BIOS that monitors and corrects BIOS corruption every 15 minutes.
  • Designed for collaboration
HP EliteBook 820 G3 - 12.5" - Core i5 6200U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (6th Gen) 6200U / 2.3 GHz (2.8 GHz) / 3 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB - M.2 SSD
Optical Drive
No optical drive
Display
12.5" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Input Device
Pointing stick
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell - up to 12.5 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, SmartCard reader
31 cm x 21.89 cm x 1.89 cm
1.26 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Enhanced SpeedStep technology, Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000 - 2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2) SATA 6Gb/s
Display
12.5" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Ultra Slim Design, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 720p
Sound
Stereo speakers, two microphones
Codec
CX7501
HP Clear Sound Amp
Audio Features
Bang & Olufsen Audio
Input
Keyboard, touchpad, pointing stick
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell Lithium Ion
44 Wh
Run Time
Up to 12.5 hours
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
USB 3.0 , USB-C , DisplayPort , VGA , LAN , Dock , Headphone/microphone combo jack , USB 3.0 (charging)
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, HP Spare Key, HP Client Security, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP Noise Reduction Software, HP Image Assistant (free download)
Case Material
Aluminum, magnesium alloy
Dockable
Security
HP DuraKeys, HP BIOS Protection, HP SureStart, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-boot Authentication
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, CCC, FCC, RoHS, WEEE
Localization
1.26 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP EliteBook 820 G3 Intel Core i5 6200U 8GB 256GB 12.5 Bundle deal on HP EliteBook 820 G3 Intel Core i5 6200U 8GB 256GB 12.5" W10P
£1,267.24
saving £8.33
£1,177.76
Optical Storage: None
Graphics: Intel HD Graphics 520
Hard Drive Type: SSD
Brand: HP
Price Range Ex VAT: 1000 - 1500
