HP EliteBook 820 G3 Intel Core i5-6200U 4GB 500GB 12.5 Windows 10 Pro
Quicklinx: CN47WS00 Mfr#: Z2X12ES#ABU
Display Size: 12.5in
Processor Model: I5-6200U
Operating System: Windows 10
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 500GB
  • Core i5
  • IEEE 802.11n
£892.55 ex VAT
£1,071.06 inc VAT
Impressively thin and light, the HP EliteBook 820 empowers users to create, connect, and collaborate, using enterprise-class performance technology that helps keep you productive in and out of the office.
Portable powerhouse
Combine high performance technology and long battery life with Windows 10 Pro, 6th Gen Intel® Core™ processors, and a PCIe Gen3 SSD. Unlock next generation memory performance with DDR4 memory for your most demanding business applications.
Slim new design with all the right ports
Connect to essential ports you need without the hassle of dongles. At just 18.9 mm, the ultraslim and light HP EliteBook 820 comes with VGA, Display Port, RJ-45, USB, USB-C™, and enterprise docking capabilities.
Strong security, powerful manageability
Protect, detect, and recover from malicious attacks with HP Sure Start with Dynamic Protection - the industry's first self-healing BIOS that monitors and corrects BIOS corruption every 15 minutes.
HP EliteBook 820 G3 - 12.5" - Core i5 6200U - 4 GB RAM - 500 GB
Notebook
Intel Core i5 (6th Gen) 6200U / 2.3 GHz / 3 MB Cache
4 GB DDR4
Storage
500 GB
Optical Drive
No optical drive
Display
12.5" LED backlight
Graphics
Intel HD Graphics 520
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell
Dockable
Security
Smart card reader
31 cm x 21.89 cm x 1.89 cm
1.26 kg
Notebook
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
4 GB
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Storage
Main Storage
500 GB
Display
12.5"
LCD Backlight Technology
LED backlight
Widescreen
Audio & Video
Graphics Processor
Camera
Yes - 720p
Sound
Stereo speakers, two microphones
Audio Features
Bang & Olufsen Audio
Input
Keyboard, touchpad
Spill-resistant
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
Network Interface
Gigabit Ethernet
Remote Management Protocol
SNMP 2
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell
AC Adapter
Input
Output
45 Watt
Connections & Expansion
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Case Material
Aluminum, magnesium alloy
Dockable
Security
Smart card reader
Security lock slot (cable lock sold separately), HP DuraKeys, HP DriveLock, Master Record Security, Power On Authentication, Pre-boot Authentication
Power adapter
RoHS
Localization
1.26 kg
35 °C
Shock Tolerance (operating)
40 g
Software applications
HP EliteBook 820 G3 Intel Core i5-6200U 4GB 500GB 12.5 Windows 10 Pro Bundle deal on HP EliteBook 820 G3 Intel Core i5-6200U 4GB 500GB 12.5 Windows 10 Pro
£991.72
Optical Storage: None
Graphics: Intel HD Graphics 520
Type: Laptop
Brand: HP
Price Range Ex VAT: 750 - 1000
