HP EliteBook 820 G3 - 12.5" - Core i5 6200U - 4 GB RAM - 256 GB SSD - Windows 7 Pro
Quicklinx: C4RLWS00 Mfr#: T9X41ET#ABU
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
Impressively thin and light, the HP EliteBook 820 empowers users to create, connect, and collaborate, using enterprise-class performance technology that helps keep you productive in and out of the office.
Portable powerhouse
Combine high performance technology and long battery life with Windows 10 Pro, 6th Gen Intel® Core™ processors, and a PCIe Gen3 SSD. Unlock next generation memory performance with DDR4 memory for your most demanding business applications.
Slim new design with all the right ports
Connect to essential ports you need without the hassle of dongles. At just 18.9 mm, the ultraslim and light HP EliteBook 820 comes with VGA, Display Port, RJ-45, USB, USB-C™, and enterprise docking capabilities.
Strong security, powerful manageability
Protect, detect, and recover from malicious attacks with HP Sure Start with Dynamic Protection - the industry’s first self-healing BIOS that monitors and corrects BIOS corruption every 15 minutes.
Designed for collaboration
Replace your speaker phone with the HP EliteBook 820 with Audio by Bang & Olufsen plus HP Noise Reduction Software that provides a rich collaboration experience for applications like Skype for Business.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful, sleek, thin, and light HP EliteBook 820.
  • Self-healing safeguard
    HP Sure Start with Dynamic Protection checks your BIOS every 15 minutes to detect attacks and corruption then self-heals the BIOS automatically.
  • Give your fingers a break
    Enjoy a remarkable balance of comfort and feedback with the HP Premium Keyboard engineered for accuracy.
  • Field ready
    Stand up to the workload with an EliteBook that passed MIL-STD 810G testing.
  • In-house serviceability
    Expand your system's memory, battery, storage, and WWAN.
  • Give your speakers a boost
    Experience the difference with HP Clear Sound AMP and the HP EliteBook 820 speakers.
HP EliteBook 820 G3 Notebook - 12.5" - Intel Core i5 - 6200U - 4 GB RAM - 256 GB SSD - UK
Ultrabook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
256 GB SSD - TLC
Display
12.5" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 520
Input Device
Pointing stick
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell - up to 12.5 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
31 cm x 21.89 cm x 1.89 cm
1.26 kg
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - parts and labour - 3 years - on-site , Limited warranty - battery - 3 years
Ultrabook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6200U / 2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 2280 SATA 6Gb/s - triple-level cell (TLC)
Display
12.5" - TN
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Slim Design, HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 1280 x 720
Sound
Stereo speakers, two microphones
Codec
CX7501
Audio Features
Output: Bang & Olufsen Audio, HP Clear Sound Amp
Input
Keyboard, touchpad, pointing stick
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Remote Management Protocol
SNMP 2
Miracast, Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell lithium polymer
44 Wh
Run Time
Up to 12.5 hours
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
Slots
1 x SIM card (1 free)
Interfaces Details
2 x USB 3.0 , USB-C , DisplayPort , VGA , LAN , Dock , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Intel Wireless Display, HP Spare Key, HP Client Security, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, HP GPS and Location, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard, HP Noise Reduction Software, HP Image Assistant
Case Material
Aluminum, magnesium alloy
Dockable
Security
HP 3D DriveGuard, HP DuraKeys, HP SpareKey, HP BIOS Protection, HP SureStart, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port, Pre-boot Authentication
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC, CIT
Localization
1.26 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
