Product
HP EliteBook 820 G2 Intel Core i7-5500U 8GB 256GB SSD 12.5" Touchscreen Windows 8.1 Pro 64-bit
Quicklinx: BHS6WS00 Mfr#: J8R59EA#ABU
  • Core i7
  • Windows 8.1 Pro 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Now employees can hit the road with a travel-ready companion. The HP EliteBook 820 thin and light notebook is ultra-mobile in and out of the office. Work with confidence thanks to proven enterprise technologies, security, performance, and management features that will meet all your enterprise's needs.
  • Portable powerhouse
    The HP EliteBook 820 with a starting weight of less than 1,36 kg/3 lbs is ideal for travel and use in enterprise environments. Stay productive with Windows 8.1 and powerful 5th Gen Intel Core processors.
  • Equipped for productivity
    Leave dongles behind with a drop-jaw Ethernet port, VGA port, and DisplayPort for key connections to all your devices. Stay connected with co-workers and customers with HP Connection Manager and optional Qualcomm Gobi 4G LTE.
  • Road ready
    Never fear bumps and minor spills. The thin, light, and stylish HP EliteBook 820 endures HP's Total Test Process and passes rigorous MIL-STD 810G testing.
  • Solid security and manageability
    All the features IT expects including an expanded security portfolio and manageability tools to fulfill the needs for your business.
HP EliteBook 820 G2 - 12.5" - Core i7 5500U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 8.1 Pro 64-bit - English
Intel Core i7 (5th Gen) 5500U / 2.4 GHz (3 GHz) / 4 MB Cache
8 GB DDR3L (1 x 8 GB)
Storage
256 GB SSD
Optical Drive
No optical drive
Display
12.5" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 5500
Input Device
Pointing stick
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
Wireless Broadband (WWAN)
4G LTE
Service Provider
Service not included
3-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, SmartCard reader
31 cm x 21.5 cm x 2.1 cm
1.34 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years , Limited warranty - battery - 3 years
Notebook
Operating System
Windows 8.1 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD SATA 6Gb/s
Display
12.5"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Full HD ultra wide-viewing angle (UWVA) anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 1280 x 720
Sound
Stereo speakers, two microphones
Codec
IDT 92HD91
High Definition Audio, DTS Studio Sound, DTS SOUND+
Input
Keyboard, touchpad, pointing stick
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7265 - PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I218-LM
Gobi Technology, Miracast
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
Generation
4G
GSM, GPRS, EDGE, WCDMA, HSPA+, LTE, DC-HSPA+, Gobi
Controller
HP lt4112 - M.2 Card
Max Transfer Rate
100 Mbps
Service Provider
Navigation
Receiver
GPS
3-cell lithium polymer
46 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
3 x USB 3.0 , DisplayPort , Headphone/microphone combo jack , LAN , Dock
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Cyberlink PowerDVD, Adobe Flash Player, Skype, Microsoft Security Essentials, HP ePrint, HP Hotkey Support, HP Spare Key, Password Manager, HP Client Security, Device Access Manager with Just In Time Authentication, HP Secure Erase, HP File Sanitizer, Drive Encryption, HP Disk Sanitizer, HP BIOSphere, HP Client Security Manager, HP Device Access Manager
Case Material
Magnesium-aluminum alloy
Dockable
Security
Power-on password, HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP DuraKeys, HP SpareKey, HP File Sanitizer, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, HP Roaming Alert, Intel My WiFi Technology, 1 USB 3.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, EAL 4+, A-Tick, ICES, KC, CIT
Localization
1.34 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
