Now employees can hit the road with a travel-ready companion. The HP EliteBook 820 thin and light notebook is ultra-mobile in and out of the office. Work with confidence thanks to proven enterprise technologies, security, performance, and management features that will meet all your enterprise's needs.
The simplicity of touch
Enjoy the intuitive control of Windows 8.1 and impressive clarity of the optional FHD touchscreen featuring tough Corning Gorilla Glass 3. -
Storage options galore
The latest storage options, including PCIe SSD, ensure optimum performance from your HP EliteBook. -
Effortless manageability
Enjoy easy integration with HP Touchpoint Manager, HP Client Management Solutions, and Intel vPro technology. -
Customized protection
HP BIOSphere keeps mission-critical data and systems protected with customizable security. -
Self-healing safeguard
HP Sure Start detects corruption and self-heals the BIOS. -
Expand your view
Stay productive throughout the day with the optional HP UltraSlim Docking Station.
- HP EliteBook 820 G2 Notebook - 12.5" - Intel Core i5 - 5200U - 4 GB RAM - 128 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
- Processor
- Intel Core i5 (5th Gen) - 5200U / 2.2 GHz, up to 2.7 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 128 GB SSD
- Display
- 12.5" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 5500
- Input Device
- Pointing stick
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 3-cell
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 31 cm x 21.5 cm x 2.1 cm
- 1.34 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years , Limited warranty - battery - 3 years
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Processor / Chipset
- CPU
- Intel Core i5 (5th Gen) 5200U / 2.2 GHz
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 128 GB SSD SATA 6Gb/s
Display
- 12.5"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Full HD ultra wide-viewing angle (UWVA) anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 1280 x 720
- Sound
- Stereo speakers, two microphones
- Codec
- ALC3228
- High Definition Audio, DTS Studio Sound, DTS SOUND+
Input
- Keyboard, touchpad, pointing stick
- Keyboard Layout
- UK
- Volume control, spill-resistant
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - PCI Express Half Mini Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- Miracast
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 3-cell lithium polymer
- Installed Qty
- 1
- Max Supported Qty
- 2
- Capacity
- 46 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- 3 x USB 3.0 , DisplayPort , VGA , Headphone/microphone combo jack , LAN , Dock
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Cyberlink PowerDVD, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, Foxit PhantomPDF Express, HP Mobile Connect, HP Systems Software Manager (free download), HP PageLift, HP UEFI System Diagnostics, HP Wireless Hotspot, Getting Started guide with Windows 8, HP GPS and Location, HP Client Catalogue (free download), HP Client Security Manager, HP Driver Packs, HP BIOS Config Utility, LANDesk Management Suite (free download), HP Device Access Manager
- Case Material
- Aluminum, magnesium alloy
- Dockable
- Security
- Power-on password, HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP DuraKeys, HP SpareKey, HP File Sanitizer, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, HP Roaming Alert, Intel My WiFi Technology, 1 USB 3.0 charging port
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, EAL 4+, A-Tick, ICES, KC, CIT
- Localization
- 1.34 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
