HP EliteBook 755 G3 AMD A10-8700B 8GB 256GB SSD 15.6" Window 7 Professional 64-bit
Quicklinx: BZ3CWS00 Mfr#: P4T46EA#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
Enjoy the thin, light, and cost effective HP EliteBook 755. Be ultra-productive by staying connected with impressive collaboration and connectivity features for your growing business on the HP EliteBook 755.
Slim new design with all the right ports
Connect with all of the essential ports you need without the hassle of dongles - in an ultra-slim design. At just 19.4 mm, the HP EliteBook 755 comes with VGA, Display Port, RJ-45 and enterprise docking capabilities.
Strong security, powerful manageability
Protect, detect, and recover from malicious attacks with HP Sure Start - the industry’s first self-healing BIOS. Keep your team up and running with HP Touchpoint Manager and DASH manageability to help monitor the HP EliteBook 755.
Designed for collaboration
Replace your speaker phone with the HP EliteBook 755 with Audio by Bang & Olufsen that provides a rich collaboration experience for applications like Skype for Business.
Great features and value, from HP!
The ultrathin HP EliteBook 755 delivers tremendous value. HP is the first to offer the new high-performance AMD PRO A12 APU, featuring integrated Radeon™ R7 graphics that help harness the full potential of your applications.
Key Features
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful, sleek, thin, and light touch optional HP EliteBook 755.
Self-healing safeguard
HP Sure Start detects attacks, corruption and self-heals the BIOS automatically.
Give your fingers a break
Keep focused without the distraction of a noisy keyboard using the HP Premium Keyboard with numeric keypad engineered for comfort.
Field ready
Stand up to the workload with an EliteBook that passed MIL-STD 810G testing.
In-house serviceability
Easily expand your system’s serviceable components.
Give your speakers a boost
Help make good speakers sound great with HP Clear Sound Amp.
Cut out the chatter
Help suppress ambient noise including keyboard clicks with HP Noise Reduction Software.
AMD Vivid Color Technology
Experience the brilliant color saturation that makes images come to life with AMD Vivid Color Technology.
  • Let nothing stand in your way
  • Self-healing safeguard
  • Give your fingers a break
  • Field ready
  • In-house serviceability
    Easily expand your system's serviceable components.
  • Give your speakers a boost
HP EliteBook 755 G3 Notebook - 15.6" - AMD A10 - PRO-8700B - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 7 Pro 64-bit - English
AMD A10 PRO-8700B / 1.8 GHz, up to 3.2 GHz / 2 MB Cache
8 GB DDR3L (1 x 8 GB)
Storage
256 GB SSD
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
AMD Radeon R6
Input Device
Pointing stick
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
3-cell - up to 8.25 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
38.33 cm x 25.77 cm x 1.94 cm
1.88 kg
Environmental Standards
- ENERGY STAR Qualified
Limited warranty - 3 years , Limited warranty - battery - 3 years
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.2 GHz
Number of Cores
Quad-Core
Cache
L2 - 2 MB
64-bit Computing
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 SATA 6Gb/s
Display
15.6" - TN
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
300 cd/m²
Slim Design, Full HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
AMD Radeon R6
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1280 x 720
Sound
Stereo speakers, two microphones
Codec
ALC3228
DTS Studio Sound
Audio Features
Output: Bang & Olufsen Audio, HP Clear Sound Amp
Input
Keyboard, touchpad, pointing stick
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Spill-resistant, touchpad with gesture support
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Broadcom BCM5762
Miracast
Wi-Fi CERTIFIED, DASH 1.1
3-cell Lithium Ion
46 Wh
Run Time
Up to 8.25 hours
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
Slots
1 x SIM card (1 free)
Interfaces Details
2 x USB 3.0 , USB-C , DisplayPort , VGA , LAN , Dock , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
HP Recovery Disc Creator, Skype, LANDesk Management Suite, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, HP Systems Software Manager, Foxit PhantomPDF Express, HP Secure Erase, HP Security Manager, HP BIOSphere, HP GPS and Location, HP Client Catalog, HP Pixel Sharp, HP Driver Packs, HP BIOS Config Utility, HP CIK for Microsoft SCCM, HP Noise Reduction Software
Case Material
Magnesium-aluminum alloy
Dockable
Security
HP 3D DriveGuard, HP DuraKeys, HP BIOS Protection, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI
Localization
1.88 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
