Take charge of your day with the HP EliteBook 750 G1 with Windows 8.1, 4th generation Intel Core i3/i5 processors, and strong security features from HP. The elegant thin and light design with optional FHD touch display makes the EliteBook ultra-productive in and out of the office. Powerful technology from HP helps you stay productive to support your thriving business.
Elegantly designed
Enjoy the elegant, thin, and lightweight design of the full-featured 39,6 cm (15.6") Ultrabook notebook. Stay productive with Windows 8.1, and powerful 4th generation Intel Core i3/i5 processors that provide excellent battery life. -
Impressively interactive
Make the most of Windows 8.1 with the intuitive control and impressive clarity of the optional FHD touchscreen featuring tough Corning Gorilla Glass 3. -
Expand your view
Add the optional HP UltraSlim docking station with two DisplayPorts to help you stay productive throughout the day. Expand your display and connectivity quickly and easily. -
Featuring
Get equipped for business with a drop-jaw Ethernet port, VGA port, DisplayPort, and USB Ports, and an optional spill-resistant backlit keyboard, and an EasyAccess panel to get to key components.Never fear bumps and minor spills. The thin and light HP EliteBook 750 G1 endures HP's Total Test Process of 115000 hours and is designed to undergo MIL-SPEC 810G tests including drop testing.Rest assured, with 24/7 phone support.Corruption detection and HP Sure Start mean you can always keep business moving.HP BIOSphere keeps mission-critical data and systems protected with customizable security.
- HP EliteBook 750 G1 Notebook - 15.6" - Intel Core i5 - 4210U - 8 GB RAM - 256 GB SSD - 4G
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- Processor
- Intel Core i5 (4th Gen) - 4210U / 1.7 GHz, up to 2.7 GHz / 3 MB Cache
- Memory
- 8 GB DDR3L (1 x 8 GB)
- Storage
- 256 GB SSD - SED
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 4400
- Input Device
- Pointing stick
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Wireless Broadband (WWAN)
- 4G
- Battery
- 3-cell
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, smart card reader
- 37.5 cm x 25.3 cm x 2.142 cm
- 1.97 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - on-site
- Product Type
- Notebook
- Recommended Use
- Small business, corporate business
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Processor / Chipset
- CPU
- Intel Core i5 (4th Gen) 4210U / 1.7 GHz
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD SATA 6Gb/s - Self-Encrypting Drive
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Full HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, stereo microphone
- Codec
- IDT 92HD91
- High Definition Audio, DTS Studio Sound
Input
- Keyboard, touchpad, pointing stick
- Volume control, spill-resistant
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- PCI Express Half Mini Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
- Generation
- 4G
- Controller
- HP lt4112
- Technology
- 3-cell lithium polymer
- Capacity
- 50 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V
Connections & Expansion
- 4 x USB 3.0 , DisplayPort , VGA , Headphone/microphone combo jack , LAN , Dock
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, Foxit PhantomPDF Express, HP Spare Key, Device Access Manager with Just In Time Authentication, HP PageLift, HP Secure Erase, Box.net 50GB storage, HP Disk Sanitizer, HP BIOSphere
- Case Material
- Magnesium-aluminum alloy
- Dockable
- Security
- Security lock slot (cable lock sold separately), HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP DuraKeys, HP SpareKey, HP DisplaySafe, HP BIOS Protection, HP SureStart, SecureBoot, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, HP Roaming Alert, 1 USB 3.0 charging port
- Included Accessories
- Power adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT
- Localization
- 1.97 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
