HP EliteBook 745 G6 Ryzen 7 3700U 8GB 256GB SSD Windows 10 Professional 64-bit
Quicklinx: FPLCWS00 Mfr#: 9FT11EA#ABU
  • IEEE 802.11n
Designed for the modern mobile professional, the HP EliteBook 745 delivers enterprise-grade security and manageability along with powerful collaboration features to keep you connected.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP.
  • Pure performance
    Take on your work with an efficiently powerful, highly secure, and reliable 2nd Gen AMD Ryzen PRO processor with Radeon VEGA graphics designed for a highly responsive experience that helps secure your data, device, and identity.
  • HP Sure Sense
    Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware.
  • Fast and efficient wireless LAN
    Get gigabit speed Wi-Fi with Wi-Fi 6 (802.11ax).
  • Protect critical security processes
    To get control of your PC, attackers first need to take down its defenses. Keep critical security protections up and running and prevent unwanted changes to security settings with HP Sure Run Gen2, which provides resilience against attacks.
  • Recovery simplified
    Advanced malware attacks can destroy your OS and disrupt your business. HP Sure Recover Gen2 ensures fast, secure, and automated recovery of your OS with only a network connection, so you can minimize downtime and get back to business fast.
HP EliteBook 745 G6 Notebook - 14" - AMD Ryzen 7 Pro 3700U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
AMD Ryzen 7 Pro 3700U / 2.3 GHz (4 GHz) / 4 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - NVMe
Display
14" WLED 1920 x 1080 / Full HD
Graphics
AMD Radeon Vega 10
Input Device
Pointing stick, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac/ax, Gigabit Ethernet
3-cell
Ambient light sensor, hall sensor
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
32.6 cm x 23.43 cm x 1.79 cm
1.5 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
Cache
4 MB
64-bit Computing
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 2280 PCIe - NVM Express (NVMe)
Display
14" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
250 cd/m²
Colour Gamut
45% NTSC
Full HD anti-glare
Keyboard Name
HP Premium Collaboration Keyboard
Audio & Video
Graphics Processor
AMD Radeon Vega 10
Camera
Yes - HD
Video Resolutions
720p
Camera Features
IR camera
Sound
Stereo speakers, 3 multi-array microphone
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard, pointing stick, ClickPad
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch clickpad, ClickPad with gesture support
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 200
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Dual stream (2x2)
3-cell Lithium Ion
50 Wh
AC Adapter
Input
Output
65 Watt
Connections & Expansion
USB-C (charging) , USB 3.1 Gen 1 (charging) , Headphone/microphone combo jack , LAN , Dock , HDMI , USB 3.1 Gen 1
Software
Software Included
HP Recovery Manager, HP Support Assistant, HP ePrint, HP Hotkey Support, HP Velocity, HP Secure Erase, HP Drive Packs (free download), HP Client Catalog, HP BIOS Config Utility, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP JetAdvantage, HP BIOSphere Gen4, HP Client Security Suite Gen4, HP Manageability & Integration Kit Gen2 (free download)
Integrated Options
Dockable
Security
Power-on password, Setup Password, Automatic DriveLock, HP DriveLock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, Master Boot Record Security, HP Sure Start Gen 4, HP Wireless Wakeup, BIOS Update via Network
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington nano security slot
USB-C power adapter
CSA, UL, VCCI, BSMI, GOST, CCC, FCC, RoHS, WEEE, A-Tick, Common Criteria EAL4+, KC, low halogen, ICCP
Localization
1.5 kg
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine wave
Shock Tolerance (non-operating)
240 g @ 2 ms half-sine wave
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
Essential Accessories (5)
Get more from your purchase from one of our essential accessories
FPLC HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack In Stock £13.44
FPLC HP Dual Head Keyed Cable Lock In Stock £43.00
FPLC HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £149.29
FPLC HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £206.71
FPLC HP Travel Hub G2 Port replicator USB-C VGA, HDMI for Chromebook In Stock £41.06
Warranty Packs (8)
Protect your investment by taking out one of our great value warranty packs
FPLC HP Care Pack Pick-Up and Return Service Extended Service Agreement 4 Years for EliteBook In Stock £107.13
FPLC HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site In Stock £94.03
FPLC HP Care Pack NBD Hardware Support for Travelers with Defective Media Retention 3 Years On-Site In Stock £109.50
FPLC HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site In Stock £104.74
FPLC HP Care Pack Pick-Up and Return Service Extended Service Agreement 5 Years Pick-Up and Return In Stock £140.47
FPLC HP EPACK 4 Year Onsite NBD+DMR (NB ONLY) In Stock £163.09
FPLC HP 3 Year Premium Care Notebook service In Stock £144.46
FPLC HP Carepack 5y Travel NextBusDay Notebook Only SVC In Stock £198.61
Other bundles (8)
FPLC HPE HDMI to DVI Adapter In Stock £9.89
FPLC HP USB-C To VGA Adapter In Stock £22.68
FPLC HP USB Travel Mouse In Stock £9.99
FPLC HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor In Stock £2,821.06
FPLC HP Premium Wireless Mouse In Stock £38.00
FPLC HP USB-C to DisplayPort Adapter In Stock £23.53
FPLC HP USB-C to HDMI 2.0 Adapter In Stock £47.06
FPLC HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor In Stock £150.00
