HP EliteBook 745 G5 Ryzen 5 2500U 8GB 256GB SSD 14" Windows 10 Pro
Quicklinx: DZ3MWS00 Mfr#: 3UP50EA#ABU
Display Size: 14in
Processor Model: 2500U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • IEEE 802.11n
£876.38 ex VAT
£1,051.65 inc VAT
Designed for the modern mobile professional, the HP EliteBook 745 offers enterprise-grade security and manageability along with powerful collaboration features to keep you connected.
  • Precision design
    Ultraslim design and a powerful viewing experience on the narrow border ultra-bright display makes working comfortable in almost any light condition. Transition from the field to the office quickly with the optional HP Thunderbolt Dock G2.
  • Built on a secure foundation
    Protect your PC against the evolving malware threats, with self-healing, hardware-enforced, and manageable security solutions from HP. From the BIOS to the browser, HP Sure Start Gen4 and HP Sure Click help secure your PC.
  • Crystal-clear collaboration
    Calls sound crisp and clear with advanced collaboration features like HP Noise Cancellation. Loud top-firing speakers produce rich sound. The world-facing third microphone and collaboration keys help make PC calls productive.
HP EliteBook 745 G5 - 14" - Ryzen 5 2500U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
AMD Ryzen 5 2500U / 2 GHz (3.6 GHz) / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD NVMe
Optical Drive
No optical drive
Display
14" WLED 1920 x 1080 / Full HD
Graphics
AMD Radeon Vega
Input Device
ClickPad
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell
Ambient light sensor
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
32.6 cm x 23.4 cm x 1.79 cm
1.49 kg
Environmental Standards
TCO Certified Notebooks 5, ENERGY STAR Qualified
Limited warranty - 3 years , Limited warranty - battery - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe - NVM Express (NVMe)
Display
14" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Keyboard Name
HP Premium Collaboration Keyboard
Audio & Video
Graphics Processor
AMD Radeon Vega
Camera
Yes - 720p
Sound
Stereo speakers, 3 multi-array microphone
Audio Features
Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Layout
Volume control, spill-resistant, multi-touch clickpad, ClickPad with gesture support
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
Network Interface
Gigabit Ethernet
3-cell Lithium Ion
50 Wh
AC Adapter
Input
Connections & Expansion
USB-C (charging) , USB 3.1 Gen 1 (charging) , Headphone/microphone combo jack , LAN , Dock , HDMI , USB 3.1 Gen 1
Software
Software Included
HP Recovery Manager, HP Support Assistant, HP ePrint, HP Hotkey Support, HP Velocity, HP Secure Erase, HP Drive Packs (free download), HP Client Catalog, HP BIOS Config Utility, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP JetAdvantage, HP BIOSphere Gen4, HP Client Security Suite Gen4, HP Manageability & Integration Kit Gen2 (free download)
Case Material
Aluminum
Integrated Options
Dockable
Security
Power-on password, Setup Password, Automatic DriveLock, HP DriveLock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, Master Boot Record Security, HP Sure Start Gen 4, HP Wireless Wakeup, BIOS Update via Network
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, CCC, FCC, RoHS, WEEE, A-Tick, Common Criteria EAL4+, KC, low halogen, ICCP
Localization
1.49 kg
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine wave
Shock Tolerance (non-operating)
240 g @ 2 ms half-sine wave
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
Software applications
HP EliteBook 745 G5 Ryzen 5 2500U 8GB 256GB SSD 14 Bundle deal on HP EliteBook 745 G5 Ryzen 5 2500U 8GB 256GB SSD 14" Windows 10 Pro
£1,055.96
saving £2.42
£975.55
Display Size: 14in
Optical Storage: None
Graphics: AMD Radeon Vega
Hard Drive Type: SSD
Type: Laptop
Brand: HP
Price Range Ex VAT: 750 - 1000
