HP EliteBook 745 G2 AMD A10 Pro-7350B 8GB 256GB SSD 14" Windows 7 Professional 64-bit
Quicklinx: BGJ9WS00 Mfr#: F1Q21EA#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
The thin and light design with optional FHD touch display makes the HP EliteBook 700 series ideal for professionals in and out of the office. Work proficiently and confidently with HP technology and AMD PRO A-Series APUs.
  • At your fingertips
    The HP EliteBook 745 G2 delivers future-ready performance at an exceptional price. Featuring AMD PRO A-Series APUs now with revolutionary HSA technology, a lightweight design, and an optional FHD touch display that allows you to navigate easily and get work done.
  • Field ready
    Never fear bumps and minor spills. The thin and light HP EliteBook 745 G2 endures HP's Total Test Process and is designed to undergo MIL-SPEC 810G testing.
  • Self-healing safeguard
    HP Sure Start is the way to help ensure a proper boot-up thanks to corruption detection, a self-healing BIOS, and recovery that restarts where it left off if the update stalls, fails, or is corrupted.
  • Featuring
    The latest AMD PRO A-Series APUs with HSA technology help unlock true business computing and deliver outstanding total cost of ownership, optimal manageability, and security features. Simply put, AMD PRO A-Series APUs are easy to support with the power to perform.Enjoy the stunning graphics provided by affordable AMD Radeon Graphics.Each HP EliteBook 745 G2 works with HP Client Management Solutions and DASH support.Work longer with your HP EliteBook 745 G2 using the optional long life slice battery built with professionals in mind.HP BIOSphere keeps mission-critical data and systems protected with customizable security.
HP EliteBook 745 G2 Notebook - 14" - AMD A10 - PRO-7350B - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
AMD A10 PRO-7350B / 2.1 GHz, up to 3.3 GHz / 4 MB Cache
8 GB DDR3L (1 x 8 GB)
Storage
256 GB SSD - SED
Display
14" LED backlight 1600 x 900 / HD+
Graphics
AMD Radeon R6
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
3-cell - up to 9 hours
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
33.9 cm x 23.7 cm x 2.1 cm
1.58 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years , Limited warranty - battery - 3 years
Notebook
Recommended Use
Small business, corporate business
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Processor / Chipset
CPU
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
Cache
L2 - 4 MB
64-bit Computing
Chipset
AMD A76M FCH
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD SATA 6Gb/s - Self-Encrypting Drive
Display
14" - TN
LCD Backlight Technology
LED backlight
Resolution
1600 x 900 (HD+)
Widescreen
HD+ standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
AMD Radeon R6
Camera
Video Resolutions
1280 x 720
Sound
Stereo speakers, stereo microphone
Codec
IDT 92HD91
High Definition Audio, DTS Studio Sound
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Network Interface
Gigabit Ethernet
Remote Management Protocol
SNMP 2
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell Lithium Ion
50 Wh
Run Time
Up to 9 hours
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
4 x USB 3.0 , DisplayPort , VGA , Headphone/microphone combo jack , LAN , Dock , Battery
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Cyberlink PowerDVD, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP ProtectTools with Credential Manager, HP Recovery Manager, HP Connection Manager, HP ePrint, HP Hotkey Support, Device Access Manager with Just In Time Authentication, HP PageLift, HP Secure Erase, HP File Sanitizer, HP Disk Sanitizer, HP BIOSphere
Security
HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP DuraKeys, HP SpareKey, HP File Sanitizer, HP DisplaySafe, HP BIOS Protection, HP Drive Encryption, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Pre-Boot Security, HP Roaming Alert, 1 USB 3.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT
Localization
1.58 kg
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance
40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance
0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
