The thin and light design with optional FHD touch display makes the HP EliteBook 700 series ideal for professionals in and out of the office. Work proficiently and confidently with HP technology and AMD PRO A-Series APUs.
At your fingertips
The HP EliteBook 745 G2 delivers future-ready performance at an exceptional price. Featuring AMD PRO A-Series APUs now with revolutionary HSA technology, a lightweight design, and an optional FHD touch display that allows you to navigate easily and get work done. -
Field ready
Never fear bumps and minor spills. The thin and light HP EliteBook 745 G2 endures HP's Total Test Process and is designed to undergo MIL-SPEC 810G testing. -
Self-healing safeguard
HP Sure Start is the way to help ensure a proper boot-up thanks to corruption detection, a self-healing BIOS, and recovery that restarts where it left off if the update stalls, fails, or is corrupted. -
Featuring
The latest AMD PRO A-Series APUs with HSA technology help unlock true business computing and deliver outstanding total cost of ownership, optimal manageability, and security features. Simply put, AMD PRO A-Series APUs are easy to support with the power to perform.Enjoy the stunning graphics provided by affordable AMD Radeon Graphics.Each HP EliteBook 745 G2 works with HP Client Management Solutions and DASH support.Work longer with your HP EliteBook 745 G2 using the optional long life slice battery built with professionals in mind.HP BIOSphere keeps mission-critical data and systems protected with customizable security.
- HP EliteBook 745 G2 Notebook - 14" - AMD A10 - PRO-7350B - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- Processor
- AMD A10 PRO-7350B / 2.1 GHz, up to 3.3 GHz / 4 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Display
- 14" LED backlight 1366 x 768 / HD
- Graphics
- AMD Radeon R6
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- 3-cell - up to 9 hours
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 33.9 cm x 23.7 cm x 2.1 cm
- 1.58 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Notebook
- Recommended Use
- Small business, corporate business
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Quad-Core
- Cache
- L2 - 4 MB
- 64-bit Computing
- Chipset
- AMD A76M FCH
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 7200 rpm
Display
- 14" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- AMD Radeon R6
- Camera
- Video Resolutions
- 1280 x 720
- Sound
- Stereo speakers, stereo microphone
- Codec
- IDT 92HD91
- High Definition Audio, DTS Studio Sound
Input
- Keyboard, touchpad
- Spill-resistant, touchpad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Network Interface
- Gigabit Ethernet
- Remote Management Protocol
- SNMP 2
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 3-cell Lithium Ion
- Capacity
- 50 Wh
- Run Time
- Up to 9 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
Connections & Expansion
- 4 x USB 3.0 , DisplayPort , VGA , Headphone/microphone combo jack , LAN , Dock , Battery
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Cyberlink PowerDVD, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP ProtectTools with Credential Manager, HP Recovery Manager, HP Connection Manager, HP ePrint, HP Hotkey Support, Device Access Manager with Just In Time Authentication, HP PageLift, HP Secure Erase, HP File Sanitizer, HP Disk Sanitizer, HP BIOSphere
- Security
- HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP DuraKeys, HP SpareKey, HP File Sanitizer, HP DisplaySafe, HP BIOS Protection, HP Drive Encryption, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Pre-Boot Security, HP Roaming Alert, 1 USB 3.0 charging port
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT
- Localization
- 1.58 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance
- 40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
- Vibration Tolerance
- 0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
