HP EliteBook 735 G6 Ryzen 3 Pro 3300U 8GB 256GB SSD 13.3" Windows 10 Professional 64-bit
Quicklinx: FNYPWS00 Mfr#: 9FT14EA#ABU
Display Size: 13.3in
Processor Model: 3300U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • IEEE 802.11n
Hurry, only 3 left in stock!
£855.06 ex VAT
£1,026.07 inc VAT
Designed for the modern mobile professional, the HP EliteBook 735 delivers enterprise-grade security and manageability along with powerful collaboration features to keep you connected.
  • Precision design
    Ultraslim design and a powerful viewing experience on the narrow border ultra-bright display makes working comfortable in almost any light condition.
  • Built on a secure foundation
    Protect your PC against the evolving malware threats, with self-healing, hardware-enforced, and manageable security solutions from HP. From the BIOS to the browser, HP Sure Start for AMD and HP Sure Click help secure your PC.
  • Crystal-clear collaboration
    Calls sound crisp and clear with advanced collaboration features like HP Noise Cancellation and an integrated world-facing microphone. Loud top-firing speakers produce rich sound and collaboration keys help make PC calls productive.
HP EliteBook 735 G6 - 13.3" - Ryzen 3 Pro 3300U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
AMD Ryzen 3 Pro 3300U / 2.1 GHz (3.5 GHz) / 4 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD NVMe, TLC, HP Value
Optical Drive
No optical drive
Display
13.3" WLED 1920 x 1080 / Full HD
Graphics
AMD Radeon Vega 6
Input Device
Pointing stick, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac/ax, Gigabit Ethernet
3-cell
Ambient light sensor, hall sensor
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
31.04 cm x 22.93 cm x 1.77 cm
1.33 kg
Environmental Standards
TCO Certified Notebooks 8, ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years , Limited warranty - software - 90 days
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
Cache
4 MB
64-bit Computing
AMD GuardMI Technology
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe - NVM Express (NVMe), triple-level cell (TLC), HP Value
Display
13.3" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
250 cd/m²
Anti-glare, 45% NTSC colour gamut
Keyboard Name
HP Premium Collaboration Keyboard
Audio & Video
Graphics Processor
AMD Radeon Vega 6
Camera
Yes - HD
Video Resolutions
720p
Camera Features
HP Privacy HD
Sound
Stereo speakers, 3 multi-array microphone
Audio Features
Bang & Olufsen Audio
Input
Keyboard, pointing stick, ClickPad
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch clickpad, ClickPad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wi-Fi 6 AX 200
Network Interface
Gigabit Ethernet
Miracast, dual stream (2x2)
Wi-Fi CERTIFIED
3-cell lithium polymer
50 Wh
AC Adapter
Input
Connections & Expansion
USB-C (charging) , USB 3.1 Gen 1 (charging) , Headphone/microphone combo jack , LAN , Dock , HDMI , USB 3.1 Gen 1
Software
Software Included
HP Support Assistant, HP Hotkey Support, Windows Defender, HP Client Catalog, HP BIOS Config Utility, HP Image Assistant, HP JumpStart, HP Noise Cancellation, HP System Software Manager, Native Miracast, HP Connection Optimizer, HP Sure Click, HP Fingerprint Sensor, HP BIOSphere Gen5, HP Client Security Manager Gen5, HP Cloud Recovery, HP Sure Sense, HP SureRun Gen2, HP Sure Recover Gen2, HP SureStart
Case Material
Aluminum
Integrated Options
Dockable
Security
Power-on password, Setup Password, BIOS Absolute Persistence, Power On Authentication, HP Fast Charge, Pre-boot Authentication, MU-MIMO technology, Master Boot Record Security, Secure Erase, BIOS Update via Network, ultra-slim
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington nano security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, CCC, FCC, RoHS, WEEE, A-Tick, Common Criteria EAL4+, KC, low halogen, ICCP, AUS/NZ
Localization
1.33 kg
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP EliteBook 735 G6 Ryzen 3 Pro 3300U 8GB 256GB SSD 13.3 Bundle deal on HP EliteBook 735 G6 Ryzen 3 Pro 3300U 8GB 256GB SSD 13.3" Windows 10 Professional 64-bit
£954.23
Optical Storage: None
Graphics: AMD Radeon Vega 6
Hard Drive Type: SSD
Brand: HP
Price Range Ex VAT: 750 - 1000
