HP EliteBook 735 G6 Ryzen 3 Pro 3300U 8GB 256GB SSD 13.3" Windows 10 Professional 64-bit
Quicklinx: FNYPWS00 Mfr#: 9FT14EA#ABU
  • IEEE 802.11n
Designed for the modern mobile professional, the HP EliteBook 735 delivers enterprise-grade security and manageability along with powerful collaboration features to keep you connected.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP.
  • HP Sure Sense
    Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware.
  • Fast and efficient wireless LAN
    Get gigabit speed Wi-Fi with Wi-Fi 6 (802.11ax).
  • Protect critical security processes
    To get control of your PC, attackers first need to take down its defenses. Keep critical security protections up and running and prevent unwanted changes to security settings with HP Sure Run Gen2, which provides resilience against attacks.
  • Recovery simplified
    Advanced malware attacks can destroy your OS and disrupt your business. HP Sure Recover Gen2 ensures fast, secure, and automated recovery of your OS with only a network connection, so you can minimize downtime and get back to business fast.
  • Browse confidently
    Help protect your PC from websites and read only Microsoft Office and PDF attachments with embedded malware, ransomware, or viruses with hardware-enforced security from HP Sure Click.
HP EliteBook 735 G6 Notebook - 13.3" - Ryzen 3 Pro 3300U - 8 GB RAM - 2 TB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
AMD Ryzen 3 Pro 3300U / 2.1 GHz (3.5 GHz) / 4 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
2 TB SSD - NVMe, TLC, HP Value
Display
13.3" WLED 1920 x 1080 / Full HD
Graphics
AMD Radeon Vega 6
Input Device
Pointing stick, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac/ax, Gigabit Ethernet
3-cell
Ambient light sensor, hall sensor
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
31.04 cm x 22.93 cm x 1.77 cm
1.33 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years , Limited warranty - software - 90 days
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
Cache
4 MB
64-bit Computing
AMD GuardMI Technology
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
2 TB SSD M.2 2280 PCIe - NVM Express (NVMe), triple-level cell (TLC), HP Value
Display
13.3" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
250 cd/m²
Colour Gamut
45% NTSC
Anti-glare
Keyboard Name
HP Premium Collaboration Keyboard
Audio & Video
Graphics Processor
AMD Radeon Vega 6
Camera
Yes - HD
Video Resolutions
720p
Camera Features
HP Privacy HD
Sound
Stereo speakers, 3 multi-array microphone
Audio Features
Bang & Olufsen Audio
Input
Keyboard, pointing stick, ClickPad
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch clickpad, ClickPad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wi-Fi 6 AX 200
Network Interface
Gigabit Ethernet
Miracast, dual stream (2x2)
Wi-Fi CERTIFIED
3-cell lithium polymer
50 Wh
AC Adapter
Input
Connections & Expansion
USB-C (charging) , USB 3.1 Gen 1 (charging) , Headphone/microphone combo jack , LAN , Dock , HDMI , USB 3.1 Gen 1
Software
Software Included
HP Support Assistant, HP Hotkey Support, Windows Defender, HP Client Catalog, HP BIOS Config Utility, HP Image Assistant, HP JumpStart, HP Noise Cancellation, HP System Software Manager, Native Miracast, HP Connection Optimizer, HP Sure Click, HP Fingerprint Sensor, HP BIOSphere Gen5, HP Client Security Manager Gen5, HP Cloud Recovery, HP Sure Sense, HP SureRun Gen2, HP Sure Recover Gen2, HP SureStart
Case Material
Aluminum
Integrated Options
Dockable
Security
Power-on password, Setup Password, BIOS Absolute Persistence, Power On Authentication, HP Fast Charge, Pre-boot Authentication, MU-MIMO technology, Master Boot Record Security, Secure Erase, BIOS Update via Network, ultra-slim
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington nano security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, CCC, FCC, RoHS, WEEE, A-Tick, Common Criteria EAL4+, KC, low halogen, ICCP, AUS/NZ
Localization
1.33 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
