Designed for the modern workforce, the cost-effective ultrathin HP EliteBook 725 helps drive performance with impressive productivity features that allow you to stay connected and collaborate at your best.
Elevated performance. Enhanced productivity.
Unleash the full potential of your applications with 6th generation or new high-performance 7th generation AMD PRO APUs with up to Radeon™ R7 integrated graphics.
Incredibly thin and impressively featured
Stay portable without having to carry adapters. Connect via VGA, Display Port™, Ethernet, USB, USB-C™, and enterprise docking capabilities, all on an 18.9mm ultrathin and light design.
Security and management made simple
HP Sure Start with Runtime Intrusion Detection protects the PC and helps ensure uninterrupted productivity by automatically detecting and recovering from BIOS corruption or attacks. Manage the fleet with HP Touchpoint Manager and DASH manageability.
Next-level collaboration
Calls and media are loud and clear letting you collaborate effectively with expertly tuned Audio by Bang & Olufsen, HP Audio Boost, HP Noise Cancellation, and premium speakers.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful, sleek, thin, light, and touch optional HP EliteBook 725.
Self-healing safeguard
HP Sure Start with Runtime Intrusion Detection monitors in-memory BIOS, recovers the platform without user or admin intervention, restores the BIOS to a custom state, and is enterprise ready for centralized management.
Get PC images right the first time
Improve the quality and security of custom Windows images with HP Image Assistant which assists ITDMs with image creation, identifies problems, and provides recommendations and remediation.
Speed up the basics of IT management
The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager.
Charge faster
Get up to 50% battery life in just 30 minutes of charging with and HP fast charging battery.
Give your speakers a boost
HP Audio Boost balances loudness and clarity, and enhances bass for improved speech quality.
Cut out the chatter
Suppress background noise including keyboard clicks with HP Noise Cancellation Software.
Office intelligence
HP WorkWise is office intelligence rolled into one smartphone app.
Unleash the full potential of your applications with 6th generation or new high-performance 7th generation AMD PRO APUs with up to Radeon R7 integrated graphics. -
Stay portable without having to carry adapters. Connect via VGA, Display Port , Ethernet, USB, USB-C , and enterprise docking capabilities, all on an 18.9mm ultrathin and light design. -
HP Sure Start with Runtime Intrusion Detection protects the PC and helps ensure uninterrupted productivity by automatically detecting and recovering from BIOS corruption or attacks. Manage the fleet with HP Touchpoint Manager and DASH manageability. -
- HP EliteBook 725 G4 - 12.5" - A10 PRO-8730B - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- AMD A10 PRO-8730B / 2.4 GHz (3.3 GHz) / 2 MB Cache
- Memory
- 4 GB DDR4 (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Optical Drive
- No optical drive
- Display
- 12.5" LED backlight 1366 x 768 / HD
- Graphics
- AMD Radeon R5
- Input Device
- Pointing stick
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 3-cell - up to 9.75 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- 31 cm x 21.89 cm x 1.89 cm
- 1.26 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 1866 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 6Gb/s / 7200 rpm
Display
- 12.5" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Brightness
- 220 cd/m²
- Slim Design, HD standard-viewing angle (SVA) eDP anti-glare
- Keyboard Name
- HP Premium
Audio & Video
- Graphics Processor
- AMD Radeon R5
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
- Audio Features
- Bang & Olufsen Audio
Input
- Keyboard, touchpad, pointing stick
- Keyboard Layout
- UK
- Spill-resistant, gesture function
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Broadcom BCM5762
- Miracast, dual stream (2x2)
- IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 3-cell lithium polymer
- Capacity
- 49 Wh
- Run Time
- Up to 9.75 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Slots
- 1 x Micro-SIM card (1 free)
- USB 3.1 Gen 1 (charging) , USB 3.1 Gen 1 , USB-C , DisplayPort , Dock , Headphone/microphone combo jack , LAN
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Skype, LANDesk Management Suite, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Client Security, HP Secure Erase, HP BIOSphere, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP Device Access Manager, HP 3D DriveGuard, HP Workwise, HP Noise Cancellation, HP System Software Manager, HP MIK for Microsoft SCCM (free download), HP JetAdvantage
- Case Material
- Aluminum, magnesium alloy
- Dockable
- Security
- HP DuraKeys, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Measured Boot, Power On Authentication, Pre-boot Authentication
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, SABS, SASO, CCC, FCC, RoHS, WEEE, ICES, KC, EAC, CIT
- Localization
- 1.26 kg
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
