HP EliteBook 725 G4 A10-8730B 4GB 500GB 12.5" Windows 10 Pro
Quicklinx: CRW8WS00 Mfr#: Z2V97EA#ABU
Display Size: 12.5in
Processor Model: A10 PRO-8730B, A10 PRO-8730B
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 500GB
  • IEEE 802.11n
£847.34 ex VAT
£1,016.80 inc VAT
Designed for the modern workforce, the cost-effective ultrathin HP EliteBook 725 helps drive performance with impressive productivity features that allow you to stay connected and collaborate at your best.
Elevated performance. Enhanced productivity.
Unleash the full potential of your applications with 6th generation or new high-performance 7th generation AMD PRO APUs with up to Radeon™ R7 integrated graphics.
Incredibly thin and impressively featured
Stay portable without having to carry adapters. Connect via VGA, Display Port™, Ethernet, USB, USB-C™, and enterprise docking capabilities, all on an 18.9mm ultrathin and light design.
Security and management made simple
HP Sure Start with Runtime Intrusion Detection protects the PC and helps ensure uninterrupted productivity by automatically detecting and recovering from BIOS corruption or attacks. Manage the fleet with HP Touchpoint Manager and DASH manageability.
Next-level collaboration
Calls and media are loud and clear letting you collaborate effectively with expertly tuned Audio by Bang & Olufsen, HP Audio Boost, HP Noise Cancellation, and premium speakers.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful, sleek, thin, light, and touch optional HP EliteBook 725.
Self-healing safeguard
HP Sure Start with Runtime Intrusion Detection monitors in-memory BIOS, recovers the platform without user or admin intervention, restores the BIOS to a custom state, and is enterprise ready for centralized management.
Get PC images right the first time
Improve the quality and security of custom Windows images with HP Image Assistant which assists ITDMs with image creation, identifies problems, and provides recommendations and remediation.
Speed up the basics of IT management
The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager.
Charge faster
Get up to 50% battery life in just 30 minutes of charging with and HP fast charging battery.
Give your speakers a boost
HP Audio Boost balances loudness and clarity, and enhances bass for improved speech quality.
Cut out the chatter
Suppress background noise including keyboard clicks with HP Noise Cancellation Software.
Office intelligence
HP WorkWise is office intelligence rolled into one smartphone app.
  • Elevated performance
    Unleash the full potential of your applications with 6th generation or new high-performance 7th generation AMD PRO APUs with up to Radeon R7 integrated graphics.
  • Incredibly thin and impressively featured
    Stay portable without having to carry adapters. Connect via VGA, Display Port , Ethernet, USB, USB-C , and enterprise docking capabilities, all on an 18.9mm ultrathin and light design.
  • Security and management made simple
  • Next-level collaboration
HP EliteBook 725 G4 - 12.5" - A10 PRO-8730B - 4 GB RAM - 500 GB HDD - QWERTY UK
Notebook
Operating System
Win 10 Pro 64-bit - English
AMD A10 PRO-8730B / 2.4 GHz (3.3 GHz) / 2 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
No optical drive
Display
12.5" LED backlight 1366 x 768 / HD
Graphics
AMD Radeon R5
Input Device
Pointing stick
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell - up to 9.75 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
31 cm x 21.89 cm x 1.89 cm
1.26 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
Cache
2 MB
64-bit Computing
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
1866 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 6Gb/s / 7200 rpm
Display
12.5" - TN
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
220 cd/m²
Slim Design, HD standard-viewing angle (SVA) eDP anti-glare
Keyboard Name
HP Premium
Audio & Video
Graphics Processor
AMD Radeon R5
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 720p
Sound
Stereo speakers, two microphones
Audio Features
Bang & Olufsen Audio
Input
Keyboard, touchpad, pointing stick
Keyboard Layout
QWERTY UK
Spill-resistant, gesture function
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Broadcom BCM5762
Miracast, dual stream (2x2)
IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell lithium polymer
49 Wh
Run Time
Up to 9.75 hours
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
Slots
1 x Micro-SIM card (1 free)
USB 3.1 Gen 1 (charging) , USB 3.1 Gen 1 , USB-C , DisplayPort , Dock , Headphone/microphone combo jack , LAN
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Skype, LANDesk Management Suite, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Client Security, HP Secure Erase, HP BIOSphere, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP Device Access Manager, HP 3D DriveGuard, HP Workwise, HP Noise Cancellation, HP System Software Manager, HP MIK for Microsoft SCCM (free download), HP JetAdvantage
Case Material
Aluminum, magnesium alloy
Dockable
Security
HP DuraKeys, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Measured Boot, Power On Authentication, Pre-boot Authentication
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, SABS, SASO, CCC, FCC, RoHS, WEEE, ICES, KC, EAC, CIT
Localization
1.26 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP EliteBook 725 G4 A10-8730B 4GB 500GB 12.5 Bundle deal on HP EliteBook 725 G4 A10-8730B 4GB 500GB 12.5" Windows 10 Pro
£1,034.98
saving £8.33
£947.10
Optical Storage: None
Graphics: AMD Radeon R5
Hard Drive Type: HDD
Brand: HP
Price Range Ex VAT: 750 - 1000
