Staying connected while you’re on the move is easy with the HP EliteBook 725. Enjoy speedy 802.11ac wireless technology and fast data transfer from the Bluetooth 4.0.
Weighing just 1.26kg and measuring 31cm x 21.89cm x 1.89cm, this EliteBook is thin and lightweight making it the ideal machine for working on the go.
Enjoy performance without compromising on speed thanks to the powerful AMD A series processor and AMD Radeon R6 graphics card.
Keep your sensitive information secure when you’re away from your notebook by implementing the security features. Choose from SmartCard reader or Trusted Platform Module security chip for the ultimate peace of mind.
The HP 725 also offers HD resolution on its 12.5-inch display for vivid image clarity – helpful when you’re making use of the integrated webcam or editing images.
And with three years’ warranty, you can ensure long-lasting performance from HP’s proven technology.
Slim new design with all the right ports
Connect with all of the essential ports you need without the hassle of dongles - in an ultra-slim design. At just 18.9 mm, the HP EliteBook 725 comes with VGA, Display Port, RJ-45 and enterprise docking capabilities.
Strong security, powerful manageability
Protect, detect, and recover from malicious attacks with HP Sure Start - the industry’s first self-healing BIOS. Keep your team up and running with HP Touchpoint Manager and DASH manageability to help monitor the HP EliteBook 725.
Designed for collaboration
Replace your speaker phone with the HP EliteBook 725 with Audio by Bang & Olufsen that provides a rich collaboration experience for applications like Skype for Business.
Great features and value, from HP!
The ultrathin HP EliteBook 725 delivers tremendous value. HP is the first to offer the new high-performance AMD PRO A12 APU, the first commercial APU with integrated Radeon™ R7 graphics that help harness the full potential of your applications.
Key Features
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful, sleek, thin, and light touch optional HP EliteBook 725.
Self-healing safeguard
HP Sure Start detects attacks, corruption and self-heals the BIOS automatically.
Give your fingers a break
Keep focused without the distraction of a noisy keyboard using the HP Premium Keyboard engineered for comfort.
Field ready
Stand up to the workload with an EliteBook that passed MIL-STD 810G testing.
In-house serviceability
Easily expand your system’s serviceable components.
Give your speakers a boost
Help make good speakers sound great with HP Clear Sound Amp.
Cut out the chatter
Help suppress ambient noise including keyboard clicks with HP Noise Reduction Software.
AMD Vivid Color Technology
Experience the brilliant color saturation that makes images come to life with AMD Vivid Color Technology.
Power through your day with Windows 10 Pro and the powerful, sleek, thin, and light touch optional HP EliteBook 725. -
HP Sure Start detects attacks, corruption and self-heals the BIOS automatically. -
Keep focused without the distraction of a noisy keyboard using the HP Premium Keyboard engineered for comfort. -
Field ready
Stand up to the workload with an EliteBook that passed MIL-STD 810G testing. -
Easily expand your system's serviceable components. -
- HP EliteBook 725 G3 Notebook - 12.5" - A10 PRO-8700B - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Processor
- AMD A10 PRO-8700B / 1.8 GHz (3.2 GHz) / 2 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Display
- 12.5" LED backlight 1366 x 768 / HD
- Graphics
- AMD Radeon R6
- Input Device
- Pointing stick
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 3-cell
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 31 cm x 21.89 cm x 1.89 cm
- 1.26 kg
- Localisation
- Language: English / region: United States
- Limited warranty - 3 years , Limited warranty - battery - 3 years
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 6Gb/s / 7200 rpm
Display
- 12.5" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Brightness
- 220 cd/m²
- Vivid Color, Slim Design, HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- AMD Radeon R6
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
- Codec
- ALC3228
- DTS Studio Sound
- Audio Features
- Bang & Olufsen Audio, HP Clear Sound Amp
Input
- Keyboard, touchpad, pointing stick
- Keyboard Layout
- UK
- Volume control, spill-resistant, touchpad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Broadcom BCM5762
- Miracast
- IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 3-cell Lithium Ion
- Capacity
- 44 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Slots
- 1 x Micro-SIM card (1 free)
- 2 x USB 3.0 , USB-C , DisplayPort , VGA , LAN , Dock , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP Pixel Sharp, HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard, HP Noise Reduction Software
- Case Material
- Magnesium-aluminum alloy
- Dockable
- Security
- HP DuraKeys, HP BIOS Protection, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, 1 USB 3.0 charging port
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI
- Localization
- 1.26 kg
