HP EliteBook 725 G2 - A series A8 PRO-7150B / 1.9 GHz - Win
Quicklinx: CCZXWS00 Mfr#: N6P94EA#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
The thin and light design with optional FHD touch display makes the HP EliteBook 700 series ideal for professionals in and out of the office. Work proficiently and confidently with HP technology and AMD PRO A-Series APUs.
At your fingertips.
The HP EliteBook 725 G2 delivers future-ready performance at an exceptional price. Featuring AMD PRO A-Series APUs now with revolutionary HSA technology, a lightweight design, and an optional FHD touch display that allows you to navigate easily and get work done.
Field ready.
Never fear bumps and minor spills. The thin and light HP EliteBook 725 G2 endures HP’s Total Test Process and is designed to undergo MIL-SPEC 810G testing.
Self-healing safeguard.
HP Sure Start is the way to help ensure a proper boot-up thanks to corruption detection, a self-healing BIOS, and recovery that restarts where it left off if the update stalls, fails, or is corrupted.
Featuring
The latest AMD A-Series Pro APUs with HSA technology help unlock true business computing and deliver outstanding total cost of ownership, optimal manageability, and security features. Simply put, AMD A-Series PRO APUs are easy to support with the power to perform.
  • At your fingertips
  • Field ready
    Never fear bumps and minor spills. The thin and light HP EliteBook 725 G2 endures HP's Total Test Process and is designed to undergo MIL-SPEC 810G testing.
  • Self-healing safeguard
  • Featuring
    The latest AMD A-Series Pro APUs with HSA technology help unlock true business computing and deliver outstanding total cost of ownership, optimal manageability, and security features. Simply put, AMD A-Series PRO APUs are easy to support with the power to perform.Each HP EliteBook 725 G2 works with HP Client Management Solutions and DASH support.Rely on stable and consistent images, managed lifecycle transitions and Elite support.HP BIOSphere keeps mission-critical data and systems protected with customizable security.
HP EliteBook 725 G2 - 12.5" - A8 PRO-7150B - 4 GB RAM - 128 GB SSD - UK
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
AMD A8 PRO-7150B / 1.9 GHz (3.2 GHz) / 4 MB Cache /
4 GB DDR3L (1 x 4 GB)
Storage
128 GB SSD
Optical Drive
No optical drive
Display
12.5" LED backlight 1366 x 768 / HD
Graphics
AMD Radeon R5
Input Device
Pointing stick
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
3-cell - up to 7.75 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
31.1 cm x 21.53 cm x 2.1 cm
1.45 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Processor / Chipset
CPU
Max Turbo Speed
3.2 GHz
Number of Cores
Quad-Core
Cache
L2 - 4 MB
64-bit Computing
Chipset
AMD A76M FCH
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
128 GB SSD SATA 6Gb/s
Display
12.5" - TN
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
200 cd/m²
HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
AMD Radeon R5
Camera
Yes - 1280 x 720
Camera Features
720p HD movie recording, low light enhancement
Sound
Stereo speakers, stereo microphone
Codec
IDT 92HD91
High Definition Audio, DTS Studio Sound, DTS SOUND+
Input
Keyboard, touchpad, pointing stick
Keyboard Backlight
Keyboard Layout
Spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111EP
Remote Management Protocol
SNMP 2
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell lithium polymer
46 Wh
Run Time
Up to 7.75 hours
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
3 x USB 3.0 , DisplayPort , VGA , Headphone/microphone combo jack , LAN , Dock
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Cyberlink PowerDVD, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, Password Manager, HP Client Security, Device Access Manager with Just In Time Authentication, HP BIOSphere, HP Credential Manager, HP Roaming Alert
Case Material
Magnesium-aluminum alloy
Dockable
Security
HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP DuraKeys, HP SpareKey, HP File Sanitizer, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, HP Roaming Alert, 1 USB 3.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, FIPS 140-2, WEEE, EAL 4+, A-Tick, ICES, KC, CIT
Localization
1.45 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
