HP EliteBook 720 G1 Intel Core i5-4210U 8GB 256GB SSD 12.5" Windows 7 Professional 64-bit
Quicklinx: BHPWWS00 Mfr#: J8Q51EA#ABU
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Take charge of your day with the HP EliteBook 720 G1 with Windows 8.1, 4th generation Intel Core i3/i5 processors, and strong security features from HP. The elegant thin and light design with optional HD Premium touch display makes the EliteBook ultra-productive in and out of the office. Powerful technology from HP helps you stay productive to support your thriving business.
  • Designed to perform
    With a starting weight of less than 3 pounds (1,33 kg), the HP EliteBook 720 G1 is ideal for the mobile professional. Stay productive on the move with Windows 8.1, powerful 4th generation Intel Core i3/i5 processors, and up to 13.5 hours of battery life.
  • Field ready
    Never fear bumps and minor spills. The thin and light HP EliteBook 720 G1 endures HP's Total Test Process of 115,000 hours and is designed to undergo MIL-SPEC 810G tests including drop testing.
  • Self-healing safeguard
    Whether working from a coffee shop or in the office, HP Sure Start Technology will protect your PC and data from malicious intended and unintended attacks.
  • Featuring
    HP BIOSphere keeps mission-critical data and systems protected with customizable security.Enjoy the intuitive control of Windows 8.1 and impressive clarity of the optional HD+ touchscreen featuring tough Corning Gorilla Glass 3.Stay productive throughout the day with the optional HP UltraSlim docking station.The latest storage options ensure optimum performance from your HP EliteBook. Choose from a range of HDD and SSD options as well as flash cache and a mini-card SSD.
HP EliteBook 720 G1 Notebook - 12.5" - Intel Core i5 - 4210U - 8 GB RAM - 256 GB SSD - 4G LTE
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Intel Core i5 (4th Gen) - 4210U / 1.7 GHz, up to 2.7 GHz / 3 MB Cache
8 GB DDR3L (1 x 8 GB)
Storage
256 GB SSD - SED
Display
12.5" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 4400
Input Device
Pointing stick
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
Wireless Broadband (WWAN)
4G LTE
3-cell - up to 13.25 hours
Security
Trusted Platform Module (TPM 1.2) Security Chip, smart card reader
31 cm x 21.53 cm x 2.1 cm
1.42 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Notebook
Recommended Use
Small business, corporate business
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Processor / Chipset
CPU
Intel Core i5 (4th Gen) 4210U / 1.7 GHz
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD SATA 6Gb/s - Self-Encrypting Drive
Display
12.5" - IPS
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HD ultra wide-viewing angle (UWVA) eDP Premium anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 1280 x 720
Sound
Stereo speakers, stereo microphone
Codec
IDT 92HD91
High Definition Audio, DTS Studio Sound
Input
Keyboard, touchpad, pointing stick
Keyboard Backlight
Volume control, spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I218-LM
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, Wi-Fi CERTIFIED, IEEE 802.3az
Generation
4G
GSM, GPRS, EDGE, WCDMA, LTE, DC-HSPA+
Controller
HP lt4112 - M.2 Card
Max Transfer Rate
100 Mbps
Navigation
Receiver
GPS
3-cell lithium polymer
46 Wh
Run Time
Up to 13.25 hours
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
3 x USB 3.0 , DisplayPort , VGA , Headphone/microphone combo jack , LAN , Dock
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Cyberlink PowerDVD, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP ePrint, CyberLink YouCam BE, Credential Manager for HP ProtectTools, Foxit PhantomPDF Express, HP Spare Key, Password Manager, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP Secure Erase, HP File Sanitizer, Drive Encryption, HP BIOSphere, HP Wireless Hotspot
Case Material
Magnesium-aluminum alloy
Security
HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP DuraKeys, HP SpareKey, HP DisplaySafe, HP BIOS Protection, HP SureStart, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, HP Roaming Alert, 1 USB 3.0 charging port
Power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT
Localization
1.42 kg
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
