Take charge of your day with the HP EliteBook 720 G1 with Windows 8.1, 4th generation Intel Core i3/i5 processors, and strong security features from HP. The elegant thin and light design with optional HD Premium touch display makes the EliteBook ultra-productive in and out of the office. Powerful technology from HP helps you stay productive to support your thriving business.
Designed to perform
With a starting weight of less than 3 pounds (1,33 kg), the HP EliteBook 720 G1 is ideal for the mobile professional. Stay productive on the move with Windows 8.1, powerful 4th generation Intel Core i3/i5 processors, and up to 13.5 hours of battery life. -
Field ready
Never fear bumps and minor spills. The thin and light HP EliteBook 720 G1 endures HP's Total Test Process of 115,000 hours and is designed to undergo MIL-SPEC 810G tests including drop testing. -
Self-healing safeguard
Whether working from a coffee shop or in the office, HP Sure Start Technology will protect your PC and data from malicious intended and unintended attacks. -
Featuring
HP BIOSphere keeps mission-critical data and systems protected with customizable security.Enjoy the intuitive control of Windows 8.1 and impressive clarity of the optional HD+ touchscreen featuring tough Corning Gorilla Glass 3.Stay productive throughout the day with the optional HP UltraSlim docking station.The latest storage options ensure optimum performance from your HP EliteBook. Choose from a range of HDD and SSD options as well as flash cache and a mini-card SSD.
- HP EliteBook 720 G1 Notebook - 12.5" - Intel Core i5 - 4210U - 8 GB RAM - 256 GB SSD - 4G LTE
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- Processor
- Intel Core i5 (4th Gen) - 4210U / 1.7 GHz, up to 2.7 GHz / 3 MB Cache
- Memory
- 8 GB DDR3L (1 x 8 GB)
- Storage
- 256 GB SSD - SED
- Display
- 12.5" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 4400
- Input Device
- Pointing stick
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Wireless Broadband (WWAN)
- 4G LTE
- Battery
- 3-cell - up to 13.25 hours
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, smart card reader
- 31 cm x 21.53 cm x 2.1 cm
- 1.42 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - on-site
- Product Type
- Notebook
- Recommended Use
- Small business, corporate business
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Processor / Chipset
- CPU
- Intel Core i5 (4th Gen) 4210U / 1.7 GHz
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD SATA 6Gb/s - Self-Encrypting Drive
Display
- 12.5" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HD ultra wide-viewing angle (UWVA) eDP Premium anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 1280 x 720
- Sound
- Stereo speakers, stereo microphone
- Codec
- IDT 92HD91
- High Definition Audio, DTS Studio Sound
Input
- Keyboard, touchpad, pointing stick
- Volume control, spill-resistant
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- PCI Express Half Mini Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, Wi-Fi CERTIFIED, IEEE 802.3az
- Generation
- 4G
- Technology
- GSM, GPRS, EDGE, WCDMA, LTE, DC-HSPA+
- Controller
- HP lt4112 - M.2 Card
- Max Transfer Rate
- 100 Mbps
Navigation
- Receiver
- GPS
- Technology
- 3-cell lithium polymer
- Capacity
- 46 Wh
- Run Time
- Up to 13.25 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- 3 x USB 3.0 , DisplayPort , VGA , Headphone/microphone combo jack , LAN , Dock
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Cyberlink PowerDVD, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP ePrint, CyberLink YouCam BE, Credential Manager for HP ProtectTools, Foxit PhantomPDF Express, HP Spare Key, Password Manager, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP Secure Erase, HP File Sanitizer, Drive Encryption, HP BIOSphere, HP Wireless Hotspot
- Case Material
- Magnesium-aluminum alloy
- Security
- HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP DuraKeys, HP SpareKey, HP DisplaySafe, HP BIOS Protection, HP SureStart, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, HP Roaming Alert, 1 USB 3.0 charging port
- Included Accessories
- Power adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT
- Localization
- 1.42 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
