HP EliteBook 1040 G4 i5 7200U / 2.5 GHz Win 10 Pro
Quicklinx: DCKHWS00 Mfr#: 1EP72EA#ABU
Display Size: 14in
Processor Model: I5-7200U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
£1,382.77 ex VAT
£1,659.32 inc VAT
With great power, comes great productivity. Our most powerful ultraslim 35.56 cm (14") diagonal business notebook accelerates your day-to-day, and makes even your hardest tasks a breeze-with powerful multitasking, on-the-go collaboration, and industry-leading security.
  • Supercharged performance
    Powered to push your pace, the HP EliteBook 1040 is ready for your biggest challenges in and out of the office. With up to 18-hours of battery life and an optional quad-core Intel Core processor (H-series) under the hood, there's almost nothing you can't handle.
  • Thin
    Say hello to the ultrathin device packed with features and ready for your mobile world. Designed for conferencing with powerful audio, intuitive call management, and a 180° hinge to share your ultra-bright 700-nit display in a huddle room.
  • Our most secure and manageable PCs
    Protection is simple and manageable thanks to a cutting-edge suite of security features that lets you browse confidently, keeps visual hackers in the dark, and monitors and restores in memory BIOS automatically.
HP EliteBook 1040 G4 - 14" - Core i5 7200U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache
8 GB DDR4 (provided memory is soldered)
Storage
256 GB - M.2 2280 SSD HP Z Turbo Drive, NVMe, TLC
Optical Drive
No optical drive
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Input Device
ClickPad
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
6-cell - up to 18 hours
Hood sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Natural silver, diamond cut design
32.89 cm x 23.28 cm x 1.59 cm
1.36 kg
Limited warranty - 3 years , Limited warranty - battery - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
DDR4 SDRAM
Speed
2133 MHz - 2133 MHz
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe - HP Z Turbo Drive, NVM Express (NVMe), triple-level cell (TLC)
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
340 cd/m²
Ultra Slim Design, 100% sRGB colour gamut, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Camera Features
IR camera, Windows Hello
Sound
Stereo speakers, dual array microphone
Audio Features
Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Multi-touch touchpad, glass with chemical etched surface
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
Miracast, dual stream (2x2)
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
6-cell Lithium Ion
67 Wh
Run Time
Up to 18 hours
AC Adapter
Input
Output
65 Watt, 5 / 9 / 10 / 12 / 15 / 20 V
Connections & Expansion
2 x USB 3.1 Gen 1 (charging) , 2 x USB-C 3.1/Thunderbolt 3 , HDMI , Headphone/microphone combo jack
Software
Software Included
HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, Device Access Manager, HP Velocity, HP Manageability, HP Drive Packs (free download), HP Client Catalog, HP BIOS Config Utility, HP 3D DriveGuard, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP System Software Manager, HP Client Security Suite Gen3, HP BIOSphere Gen3, HP JetAdvantage, HP Wireless Wakeup, HP Management Integration Kit for Microsoft System Center Configuration Manager (free download), HP Sure Click
Case Material
Aluminum
Integrated Options
Hood sensor
Security
Power-on password, Setup Password, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, HP Fast Charge, MIL-STD-810G tested, HP Sure Start Gen 3
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
USB-C power adapter
Localization
1.36 kg
Software applications
HP EliteBook 1040 G4 i5 7200U / 2.5 GHz Win 10 Pro Bundle deal on HP EliteBook 1040 G4 i5 7200U / 2.5 GHz Win 10 Pro
£1,569.23
saving £8.33
£1,474.31
Display Size: 14in
Optical Storage: None
Graphics: Intel HD Graphics 620
Hard Drive Type: SSD
Type: Laptop
Brand: HP
Price Range Ex VAT: 1000 - 1500
