HP EliteBook 1040 G3 - Core i7 6500U / 2.5 GHz - Windows 10 Professional
Quicklinx: CH3DWS00 Mfr#: Y3B80EA#ABU
  • Core i7
  • IEEE 802.11n
The sophisticated style of the HP EliteBook 1040 Ultrabook complements the innovative performance, security, and manageability features that help bring out your finest work.
Carry less, do more
Work confidently with the thin, elegant, and durable HP EliteBook 1040 with the HP Premium Keyboard, and a strong all metal diamond cut design that passed MIL-STD 810G testing.
Productive powerhouse
Power through your day with long battery life, 6th Gen Intel® Core™ processors, up to 16 GB of memory, and PCIe SSDs that yield impressive speed and performance.
Connect and collaborate in style
Collaborate with colleagues from practically anywhere with optional WWAN, a 720p webcam, HP Noise Reduction Software and Audio by Bang & Olufsen.
Security and manageability you can depend on
Manage devices easily with optional Intel® vPro,™ and LANDesk management that integrates with advanced IT environments and help reduce costly downtime with innovative BIOS protection from HP Sure Start with Dynamic Protection.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful, collaboration-ready HP EliteBook 1040.
  • Performance to get the job done
    Innovative performance with 6th Gen Intel Core processor, PCIe SSDs, and long battery life lets you work, surf, and connect with colleagues.
  • Easy connections
    Instantly protect against visual hacking with the optional HP Sure View integrated privacy screen, featuring 3M privacy technology. At the touch of a button your screen appears dark to those around you while you see your content clearly.
  • Give your fingers a break
    Enjoy a remarkable balance of comfort and feedback with the HP Premium Keyboard.
  • Strong security
    Protect, detect, and recover from malicious BIOS attacks with HP Sure Start with Dynamic Protection - the industry's first self-healing BIOS that monitors and corrects BIOS corruption in real-time.
  • Safeguard data and devices
    Help protect your PC with multifunction authentication using a fingerprint reader, SmartCard Reader, and TPM.
HP EliteBook 1040 G3 Notebook - 14" - Intel Core i7 - 6500U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (6th Gen) - 6500U / 2.5 GHz, up to 3.1 GHz / 4 MB Cache
8 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD
Display
14" WLED 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Input Device
ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, NFC, Bluetooth 4.2, Gigabit Ethernet
6-cell - up to 9.75 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
33.7 cm x 23.45 cm x 1.58 cm
1.43 kg
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i7 (6th Gen) 6500U / 2.5 GHz
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (provided memory is soldered)
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
Storage
Main Storage
256 GB SSD M.2 SATA 6Gb/s
Display
14"
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Full HD standard-viewing angle (SVA) anti-glare
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 720p
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
720p HD movie recording, low light enhancement
Sound
Stereo speakers, two microphones
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad, glass with chemical etched surface
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I218-LM
Intel Wireless Display (WiDi), Miracast
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
6-cell lithium polymer
45.6 Wh
Run Time
Up to 9.75 hours
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
Interfaces Details
2 x USB 3.0 , USB-C , Dock , HDMI , Headphone/microphone combo jack , VGA (on supplied cable)
Software
Software Included
Cyberlink PowerDVD, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, HP ePrint, CyberLink YouCam BE, Foxit PhantomPDF Express, HP PageLift, HP File Sanitizer, HP BIOSphere, HP Wireless Hotspot, HP Touchpoint Manager, Skype for Business Plus CAL
Case Material
Aluminum
Dockable
Security
HP DuraFinish, HP DuraKeys, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, RoHS, WEEE
Localization
1.43 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
Essential Accessories (5)
Get more from your purchase from one of our essential accessories
CH3D HP 90W Smart AC Adapter In Stock £22.69
CH3D HP 45W Adaptor NPFC Smart RC 4.5MM NSLIM In Stock £16.87
CH3D HP 65W Smart AC Adapter In Stock £18.54
CH3D HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack In Stock £13.44
CH3D HP Dual Head Keyed Cable Lock In Stock £43.00
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
CH3D HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site In Stock £123.80
Other bundles (7)
CH3D HPE HDMI to DVI Adapter In Stock £9.89
CH3D HP USB Travel Mouse In Stock £10.14
CH3D HP X4000b Bluetooth Mouse In Stock £28.71
CH3D HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor In Stock £2,821.06
CH3D HP Premium Wireless Mouse In Stock £38.00
CH3D HP E23 G4 23" 1920x1080 5ms USB VGA HDMI FHD Monitor In Stock £157.28
CH3D HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor In Stock £144.44
