HP EliteBook 1030 IntelCore M5-6Y54 8GB 256GB SSD 13.3" Windows 10 Professional 64-bit
Quicklinx: C4RZWS00 Mfr#: X2F07EA#ABU
  • IEEE 802.11n
The premium design of the beautifully compact and durable HP EliteBook 1030 delivers style and substance. The amazing near edge-to-edge screen makes it a great travel companion that's fully equipped with HP's leading security and manageability solutions.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful HP EliteBook 1030 with built-in security, collaboration, and connectivity.
  • Performance to get the job done
    Long battery life lets you work, surf, and connect with colleagues. Latest 6th Gen Intel Core processors , solid state drives, and up to 16 GB of memory give you the performance you need.
  • Give your speakers a boost
    Get the most from your speakers with the HP Clear Sound Amp.
  • Give your fingers a break
    Enjoy a remarkable balance of comfort and feedback with the crisp key response and consistent force of the HP Premium Keyboard.
  • Create the total package
    Elevate your EliteBook by adding an optional docking station, Elite curved display, and more.
  • Strong security, powerful manageability
    Protect, detect, and recover from malicious BIOS attacks using HP Sure Start with Dynamic Protection - the industry's first self-healing BIOS that monitors and corrects BIOS corruption in real-time.
HP EliteBook 1030 G1 Notebook - 13.3" - Intel Core m5 - 6Y54 - vPro - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Platform Technology
Intel vPro Platform
Intel Core m5 (6th Gen) - 6Y54 / 1.1 GHz, up to 2.7 GHz / 4 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD - NVMe
Display
13.3" LED backlight touchscreen 3200 x 1800 / QHD+
Graphics
Intel HD Graphics 515
Input Device
ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, NFC, Bluetooth 4.2
4-cell - up to 9 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
31 cm x 21 cm x 1.57 cm
1.16 kg
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core m5 (6th Gen) 6Y54 / 1.1 GHz
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Platform Technology
Intel vPro Platform
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
256 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
13.3" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
3200 x 1800 (QHD+)
Widescreen
Image Brightness
300 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Sound
Stereo speakers, two microphones
Audio Features
Output: Bang & Olufsen Audio, HP Clear Sound Amp, Intel Smart Sound
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Spill-resistant, touchpad with gesture support, glass with chemical etched surface
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
Intel Wireless Display (WiDi), Miracast
IEEE 802.11i, Wi-Fi CERTIFIED
4-cell Lithium Ion
40 Wh
Run Time
Up to 9 hours
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
Interfaces Details
2 x USB 3.0 , USB-C , Dock , HDMI , Headphone/microphone combo jack
Software
Software Included
HP Recovery Disc Creator, Skype, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Intel Wireless Display, Password Manager, HP Client Security, HP Systems Software Manager (free download), HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP Noise Reduction Software, HP Image Assistant (free download)
Dockable
Security
Intel Active Management Technology (iAMT), HP DuraKeys, HP SpareKey, HP BIOS Protection, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Measured Boot, Power On Authentication, Pre-Boot Security, 2 x USB 3.0 charging port, Pre-boot Authentication, HP Sure Start with Dynamic Protection, 1 USB-C charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, VCCI, BSMI, CCC, FCC, A-Tick, ICES, KC, CIT
Localization
1.16 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
35 °C
10 - 90%
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
