The premium design of the beautifully compact and durable HP EliteBook 1030 delivers style and substance. The amazing near edge-to-edge screen makes it a great travel companion that's fully equipped with HP's leading security and manageability solutions.
See more, carry less
Get big screen views from the compact and sophisticated design of the HP EliteBook 1030 with its near edge-to-edge 33,8 cm (13.3') diagonal screen and the diamond-cut all metal design.
The strong, quiet type
Work comfortably and without distraction. Focus on task at hand, the HP EliteBook 1030 runs quietly and stays cool with no fans or spinning drives.
Innovative security and manageability only from HP
Help reduce costly downtime using innovative BIOS protection from HP Sure Start with Dynamic Protection and manage devices easily with optional Intel® vPro™, HP Touch Manager or LANDesk management that integrates with advanced IT environments.
Connect and collaborate in style
Collaborate with colleagues using the HD Webcam and HP Noise Reduction Software that greatly reduces background noise. Clearly hear presenters on expertly tuned speakers with Audio by Bang & Olufsen powered up with the HP Clear Sound Amp.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful HP EliteBook 1030 with built-in security, collaboration, and connectivity. -
Performance to get the job done
Long battery life lets you work, surf, and connect with colleagues. Latest 6th Gen Intel Core processors , solid state drives, and up to 16 GB of memory give you the performance you need. -
Give your speakers a boost
Get the most from your speakers with the HP Clear Sound Amp. -
Give your fingers a break
Enjoy a remarkable balance of comfort and feedback with the crisp key response and consistent force of the HP Premium Keyboard. -
Create the total package
Elevate your EliteBook by adding an optional docking station, Elite curved display, and more. -
Strong security, powerful manageability
Protect, detect, and recover from malicious BIOS attacks using HP Sure Start with Dynamic Protection - the industry's first self-healing BIOS that monitors and corrects BIOS corruption in real-time.
- HP EliteBook 1030 G1 Notebook - 13.3" - Intel Core m7 - 6Y75 - vPro - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core m7 (6th Gen) - 6Y75 / 1.2 GHz, up to 3.1 GHz / 4 MB Cache
- Memory
- 16 GB LPDDR3 (provided memory is soldered)
- Storage
- 512 GB SSD
- Display
- 13.3" touchscreen 3200 x 1800 / QHD+
- Graphics
- Intel HD Graphics 515
- Input Device
- ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, NFC, Bluetooth 4.2
- Battery
- 4-cell - up to 9 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- 31 cm x 21 cm x 1.57 cm
- 1.16 kg
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 3 years , Limited warranty - battery - 3 years
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core m7 (6th Gen) 6Y75 / 1.2 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 16 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
Storage
- Main Storage
- 512 GB SSD M.2 PCIe
Display
- 13.3" - IPS
- Touchscreen
- Resolution
- 3200 x 1800 (QHD+)
- Widescreen
- Image Brightness
- 300 cd/m²
- QHD+ eDP anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
- Audio Features
- Output: Bang & Olufsen Audio, HP Clear Sound Amp, Intel Smart Sound
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Spill-resistant, touchpad with gesture support, glass with chemical etched surface
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
- Intel Wireless Display (WiDi), Miracast
- IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Capacity
- 40 Wh
- Run Time
- Up to 9 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- 2 x USB 3.0 (charging) , USB-C (charging) , Dock , HDMI , Headphone/microphone combo jack
Software
- Software Included
- HP Recovery Disc Creator, Skype, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Intel Wireless Display, Password Manager, HP Client Security, HP Systems Software Manager (free download), HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP Noise Reduction Software, HP Image Assistant (free download)
- Dockable
- Security
- Intel Active Management Technology (iAMT), HP DuraKeys, HP SpareKey, HP BIOS Protection, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Measured Boot, Power On Authentication, Pre-Boot Security, 2 x USB 3.0 charging port, Pre-boot Authentication, HP Sure Start with Dynamic Protection, 1 USB-C charging port
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- CSA, UL, VCCI, BSMI, CCC, FCC, A-Tick, ICES, Common Criteria EAL4+, KC, CIT
- Localization
- 1.16 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90%
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
