The HP EliteBook Folio 1020 Bang & Olufsen Limited Edition is an impressively thin and light business-class notebook with state-of-the-art Audio by Bang & Olufsen. It's fully equipped with HP's leading security and manageability solutions and Windows 10 Pro.
Remote conferencing made easy
Collaborate with colleagues around the world using optional Skype for Business and an HD webcam for an impressive visual experience. Audio by Bang & Olufsen, and HP Noise Reduction Software combine to produce an immersive audio experience. -
Sleek, slim, smart
Show off the dark ash color scheme with copper colored accents on a notebook that not only has the smarts, but looks the part with a sleek diamond cut design. -
Streamlined security and management
Rely on powerful security, comprehensive management solutions, and new Windows 10 Pro features to help keep devices, data, and identities secure. Easily manage your devices with powerful tools from HP including HP Touchpoint Manager. -
Tough and ready
Confidently take on the rigors of everyday use and travel with a resilient EliteBook with long battery life that is engineered with no moving parts and designed to pass MIL-STD 810G durability tests for drop, shock, vibration and more.
- HP EliteBook Folio 1020 G1 - Bang & Olufsen Limited Edition - 12.5" - Core M 5Y71 - vPro - 8 GB RAM - 512 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core M (5th Gen) 5Y71 / 1.2 GHz (2.9 GHz) / 4 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 512 GB SSD
- Display
- 12.5" LED backlight touchscreen 2560 x 1440 / WQHD
- Graphics
- Intel HD Graphics 5300
- Input Device
- ForcePad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac
- Battery
- 4-cell - up to 9 hours
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 31 cm x 21 cm x 1.57 cm
- 1.27 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year
- Bundled Services
- 3 Years HP Care Pack Pick-Up and Return Service for Travellers
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.9 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 4 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 512 GB SSD M.2 SATA 6Gb/s
Display
- 12.5"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Resolution
- 2560 x 1440 (WQHD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Ultra Slim Design, QHD ultra wide-viewing angle (UWVA) eDP
Audio & Video
- Graphics Processor
- Camera
- Yes - 1280 x 720
- Camera Features
- 720p HD movie recording, low light enhancement
- Sound
- Stereo speakers, two microphones
- High Definition Audio, DTS Studio Sound
Input
- Keyboard, ForcePad
- Keyboard Layout
- UK
- Spill-resistant, touchpad with gesture support
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265
- Technology
- 4-cell lithium polymer
- Capacity
- 36 Wh
- Run Time
- Up to 9 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- 2 x USB 3.0 , HDMI , Dock , Headphone/microphone combo jack , LAN (on supplied cable) , VGA (on supplied cable)
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Drivers & Utilities, Adobe Flash Player, HP Recovery Disc Creator, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, HP Spare Key, HP Systems Software Manager (free download), HP PageLift, HP Secure Erase, HP File Sanitizer, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP Client Security Manager, HP Device Access Manager, HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard
- Case Material
- Aluminum, magnesium alloy
- Dockable
- Security
- Noise reduction, fanless, HP 3D DriveGuard, Intel Active Management Technology (iAMT), HP DuraKeys, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security, Intel My WiFi Technology, 2 x USB 3.0 charging port
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter, HP Dock Connector to Ethernet/VGA Adapter
- ACPI, WHQL, RoHS, WEEE
- Localization
- 1.27 kg
- ENERGY STAR Certified
- Bundled Services
