Shield your HP Elite x3 from whatever the day may bring with the anti-slip grip, shock-absorbing HP Elite x3 Rugged Case, which is designed to pass MIL-STD drop testing up to 6 feet (1.8 m).
Smart, stylish design
Slide your HP Elite x3 into a sleek, carbon fiber-inspired case that maintains its slim profile and offers reinforced device screen protection with a raised, beveled edge. -
Unlimited access
Retain access to your HP Elite x3's buttons, cameras, and connectors, and use the built-in lanyard holes to secure your pen. -
Compatible with your ecosystem
Use the case with the HP Elite x3 Screen Protectors, Privacy Screen, Wireless Charger, and Desk Dock. -
World-class support
Get a one-year limited warranty.
- HP - protective case - back cover for mobile phone
- Product Type
- Protective case back cover for mobile phone
- 8.809 cm x 1.02 cm x 16.643 cm
- 32 g
- Material
- Plastic, carbon fibre
- 1-year warranty
- Designed For
- Elite x3
- 8.809 cm
- 1.02 cm
- 16.643 cm
- 32 g
- Rugged
- Material
Carrying Case
- Protective case
- Recommended Use
- For mobile phone
- Cover Type
- Back cover
- MIL-STD 810G
- 1-year warranty
- Designed For
- HP Elite x3
